Old 05-23-2018, 06:56 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Wheel Spec Recommendations (Subaru BRZ)
Apologies in advance because I just recently bought my BRZ and am unfamiliar with a lot of the wheel specs.
Car is 2013 Subaru BRZ stock everything, if I wanted to run a 19" wheel in the rear (Say, 10.5" in width) and an 18" wheel in the front (9 to 9.5" in width), what would I be looking for in terms of making sure it fits? (Suspension, offset, etc.)
Thanks!
scottryan is offline   Reply With Quote
Old 05-23-2018, 07:22 PM   #2
Racecomp Engineering
Ooof.
What are your goals with your car? Show car? Daily driver?
19x10.5 is....a lot.
- Andrew
wparsons (05-24-2018)
Old 05-23-2018, 07:48 PM   #3
scottryan
Financial Distress
scottryan's Avatar
Ooof.
- Andrew
It's pretty much a daily drive, but not a hard or long drive, I take good care of my stuff. I'll take your word that 19x10.5 would be a little crazy, so If I wanted to run a bit of a wider wheel in the back, what would you recommend? (I'd like the wheel to line up flush with the wheel well)
thanks for the response by the way!
Old 05-23-2018, 08:09 PM   #4
monkeybike
Drives: 86
This thread will help - http://www.ft86club.com/forums/showthread.php?t=7535
monkeybike is offline   Reply With Quote
The Following User Says Thank You to monkeybike For This Useful Post:
x808drifter (05-23-2018)
Old 05-23-2018, 08:39 PM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
What's the look you going for?
This
Or This....
Old 05-23-2018, 09:26 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
x808drifter: probably none of these two. They are not welded suspension land-scraping slammed and camber at least 10 degrees less then planned
Old 05-24-2018, 12:07 AM   #7
scottryan
Financial Distress
scottryan's Avatar
x808drifter
Damn those don't look photoshopped at all
Old 05-24-2018, 12:11 AM   #8
scottryan
Financial Distress
scottryan's Avatar
Originally Posted by monkeybike View Post
Thanks my friend, I came across this and will definitely refer to it, was just hoping for some recommendations from some people who have gone with larger wheels themselves.
I appreciate the reply!
Old 05-24-2018, 11:08 AM   #9
Offset and width are what dictate if the wheel is sunk in or poking out or flush. So you could have a (normal, reasonable, functional) 8 inch wide wheel with the right offset and it will be nice and flush.
Not a lot of people run 19 inch wheels on these cars because:
1. They can be expensive
2. 19 inch tires can be expensive.
3. They are usually very heavy, negatively impacting acceleration, ride, and handling.
4. They require thin sidewall tires, negatively impacting ride.
If done right, the impact on the way the car drives is reduced. But there is zero functional benefit to them.
Everyone has different tastes visually and different priorities for their car. But a car with heavy 19 inch wheels will be less fun to drive. For me, that's the most important thing.
I would highly recommend a quality 18x8 or 18x9 inch wheel with the right offset if you really want a larger size wheel. At the very least, do some extra reading before you spend a whole bunch of money on wheels. The link @monkeybike posted is very helpful.
Staggering, or using a wider wheel at the back, isn't ideal for performance but not the end of the world. It does make rotating tires difficult.
- Andrew
<-----my 17x8 +40 offset wheels are being delivered tomorrow yayyyyy
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
churchx (05-24-2018), Leonardo (05-24-2018), rvoll (05-24-2018), Tristor (05-24-2018), wparsons (05-24-2018)
Old 05-24-2018, 12:39 PM   #10
wparsons
wparsons's Avatar
17x8 +35 will be very close to flush, without compromising ride, handling, etc.
That said, if you want to stick with your original thoughts (10.5 rear, 9.5 front) you'll need coilovers (smaller diameter spring, more clearance up front before the wheel/tire hits the spring seat) and more camber to keep them under the fenders. Different diameters will look crappy IMO, and the extra weight and staggered will make the car a lot less fun to drive.
flickr
Old 05-24-2018, 12:56 PM   #11
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
i second the 17x8. i feel like for an NA car 8" wheels are plenty enough, get the proper offset (30-35) and with the right camber and a mild drop (.8-1") and youre golden in my opinion
JustSomeGuy is offline   Reply With Quote
The Following 2 Users Say Thank You to JustSomeGuy For This Useful Post:
rvoll (05-24-2018), wparsons (05-24-2018)
Old 05-24-2018, 03:11 PM   #12
scottryan
Financial Distress
scottryan's Avatar
- Andrew
Thank you so much Andrew, I appreciate the info! I'll definitely be going with eh 18" wheel route instead.
The Following User Says Thank You to scottryan For This Useful Post:
Racecomp Engineering (05-24-2018)
Old 05-24-2018, 03:12 PM   #13
scottryan
Financial Distress
scottryan's Avatar
Thank you for the recommendation, I'll go with something a lot closer to if not the same as what you said here. I don't want to diminish the drive so I'll stick with the 18's and continue to do my homework. Thanks again to both of you guys
JustSomeGuy (05-24-2018)
Old 05-24-2018, 03:29 PM   #14
JustSomeGuy
A Nobody
Drives: FRS
from the rear shows very good what 17x8 +35 looks like for an idea
The Following User Says Thank You to JustSomeGuy For This Useful Post:
brz, subaru, wheels
Can ya'll help me with some wheel recommendations? Is Always Angry Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-30-2017 05:50 PM
Need alignment spec recommendations 8RZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 05-10-2017 09:53 PM
Wheel Paint Recommendations? flameSniper Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-28-2015 08:15 PM
Wheel recommendations? cncnjn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-09-2013 06:30 PM
Wheel Directory: Subaru Legacy Spec B 18x7.0 +55 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-19-2012 05:52 PM
