The Gunshine State
Drives: '14 BRZ Limited
Need alignment spec recommendations
So I just installed Megan coilovers and will be doing the first alignment on it. The suspension does not have front adj. camber plates but I did buy front camber bolts (rear is all stock).
I mainly do spirited city driving with occasional autox (only 3 times last year and none this year yet). I have heard some negative camber would be beneficial but how much in the front and rear exactly should I tell the shop? I plan on 0 toe, is castor adjustable on our cars? Thanks.
![]() Current DD: M235i |
#3 | |
The Gunshine State
Like I stated, mostly daily driving on the street with occasional autox. -1.5-2 all around sounds like a good start.
Drives: 2013 Subaru BRZ
You can get nearly 2.0 degrees rear camber with Subaru crash bolts. Subaru sells these to correct rear alignment problems.
Because compromise ®
Drives: Red Herring
It has been suggested rear camber should be initially setup with 0.5 less negative camber than front given the different wheel geometries (Mac strut vs upper/lower control arm). E.g. Front camber -3.2, rear camber -2.7.
Drives: 2014 GT86
"You can get nearly 2.0 degrees rear camber with Subaru crash bolts. Subaru sells these to correct rear alignment problems"
Rear camber with crash bolts? Not eccentric bushings? And it's Subaru, not Whiteline? rear alignment problems? My conviction that he is trolling just grows stronger by each post. |
| The Following User Says Thank You to churchx For This Useful Post: | sugoi (05-10-2017) |
The Gunshine State
I have a staggered setup, would this still hold true for me?
Drives: Red Herring
I do not know but I am thinking that given the differing roll rates front and rear (I am suggesting the more grip at the rear will cause more roll at the rear) you may want a different delta f/r camber.
Let me emphasise this is just conjecture on my part. The proper way to set camber is with a pyrometer.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | 8RZ (05-10-2017) |
Drives: 2017 BRZ
| The Following 2 Users Say Thank You to cjd For This Useful Post: | Captain Snooze (05-10-2017), Lynxis (05-10-2017) |
#10 |
The Gunshine State
I never claimed it was, majority city/hwy driving.
#11 | |
Drives: 2013 WRB BRZ 6MT
Note that rear camber isn't adjustable on the stock hardware, you need either adjustable rear lower control arms or eccentric bushings so you are going to get what you get in the rear without one of those. The suggestions for a bit less camber in the rear than the front is because the front is macpherson strut and the rear is multilink. As a result, the rear gets more camber under compression than the front does. To adjust for this, most people aim for around 0.5 degrees more in the front than the rear to even it out. |
| The Following User Says Thank You to Lynxis For This Useful Post: | 8RZ (05-10-2017) |
#13 |
Drives: 2017 BRZ
#14 |
Drives: 2014 GT86
That sounds to me like much more grip needs to be added in front relative to rear. Be it in way of extra camber, lesser swaybar or whatever. Of course my real choice would be to not get staggered wheel/tire setup in first place, to not have to workaround it. Even selling staggered set of used wheels is much harder as there are way less potential buyers who would want such.
| Alignment recommendations for my setup? | sqd | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-19-2016 01:33 PM |
| Need Insight on Shop Recommendations - Alignment | Ammunition | Northwest | 19 | 04-29-2016 02:04 AM |
| Alignment shop recommendations? (SEA) | Koa | Northwest | 7 | 02-16-2015 07:18 PM |
| Alignment Shop Recommendations (San Diego) | RMP | Tracking / Autocross / HPDE / Drifting | 3 | 07-25-2014 04:14 AM |
| Recommendations for alignment in Socal | anewprelusion | Southern California | 18 | 01-13-2014 02:36 PM |
