Old 08-29-2017, 02:56 PM   #1
sid94
Drives: 2013 frs
Timing cover leak
I got a leak coming from my timing cover in the driver's side I'm out of warranty
Baisically what I want to know if anybody on here has resealed it themselves, I'm a tech so it's not a problem just want to know if anyone here has the list of the parts I would need to do the job
I have extended warranty but if the cost of parts is less then my deductible I'd rather do it myself
sid94 is offline   Reply With Quote
Old 09-18-2017, 10:29 AM   #2
sIowbrz
Drives: 2015 brz
if your asking these question obviously ur not a tech
sIowbrz is offline   Reply With Quote
Old 10-19-2017, 02:24 AM   #3
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
Hey, He's just raising a question, I had the same issue and it was fixed at the dealer. Only thing is the issue came back again about 6 months later. My leak is on the bottom left side when your looking at the engine from the front.
RAYS TE37V 17X9 / MICHELIN 245/40/R17 / KW V3 / RACESENG TOP HATS / MOTUL 5.1 + BRAIDED LINES / FERODO DS2500 BRAKE PADS / NEXUS 7 IN DASH / VDS UEL HEADERS / CRAWFORD POWER BLOCKS/ K&N DROP IN FILTER / Custom 3 inch header back catless exhaust / Varex 3in Muffler / HT AUTO LIP KIT / VALENTI TAIL LIGHTS / MORIMOTO PROJECTOR + HID.
MaXimus is offline   Reply With Quote
Old 12-16-2017, 02:05 PM   #4
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Is it just sealant or a gasket?
Respect BRZ is offline   Reply With Quote
Old 12-16-2017, 03:11 PM   #5
sid94
Drives: 2013 frs
Sealant
Threebond 1217G or equivalent anything else will more then likely leak
Old 12-16-2017, 03:19 PM   #6
sid94
Drives: 2013 frs
Cause I’m asking for a parts list? There were 4 o-rings along with the 2 seal per each cam cover and the front main and the other seal that goes on crank I was Try to avoid going to the dealer by providing part numbers
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 4 04-03-2018 03:06 PM
Timing Cover Oil Leak AllDayJonRay Issues | Warranty | Recalls / TSB 18 06-06-2016 03:12 AM
Timing Cover Oil Leak Keenercarguy Issues | Warranty | Recalls / TSB 66 05-30-2016 11:59 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
