Old 05-17-2018, 02:09 AM   #1
Estrada E
Drives: Subaru BRZ
Smile Fitment help 😅
So I just bought some ambit re02s 18 x9.5 +38 and am going to buy either tein super low flex z’s or street basis z’s coilovers but don’t know What kind of tire specs can somewhat make me achieve this look, I’m not trying to go to low but lower than stock for sure. Would 245 or 255 40 18 work with no rubbing issues ?
http://cdn.shopify.com/s/files/1/069...90512957969851
Estrada E is offline   Reply With Quote
Old 05-17-2018, 10:56 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
How low are you trying to go? I am 17x9 +38 with 245's and I rub under the fender liner on hard cornering. I am also 2 inches lower then stock. Your camber will also effect fitment quite a bit.
Old 05-17-2018, 11:59 AM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Depending on how low you go, you may also need LCA and endlinks.
Don't get 245/40 or 255/40. They have to large of a diameter. Get 245/35 or 255/35; they will fit better and will keep your speedo accurate. 245/35/18 is stock diameter. You could run 245/35 front and 255/35 rear also if you wanted.
I LIKE TIRES!
Old 05-19-2018, 07:34 PM   #4
Estrada E
Drives: Subaru BRZ
I’m trying to go maybe an inch or so from the fender and yeah I’m probably guna have to camber it a little bit not trying to go crazy on that
Old 05-19-2018, 07:46 PM   #5
Estrada E
Drives: Subaru BRZ
Would 245 40 not fit I’ve seen guys run it, I’m trying to go for that meaty look that’s why, would 240 40 work ? Would I really need lca’s though or would it run fine without them ?
Old 05-19-2018, 08:35 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Street basis reuse the stock tophats. You will get some rear camber by lowering the car, but no way to adjust it. FlexZ has tophats with camber adjustment. A 245/40/18 is 25.7" diameter. Stock is 24.6" diameter, which is larger than a 3% difference. (which is the general rule of thumb for plus sizing - less than 3% difference) I have seen guys run that size to though. I would still get 35 series.
I lowered my car 1" and have -2.2 rear natural camber. (no adjustment) So, if you go lower you will have more, unless you have a way to adjust it.
I tried to find a answer if you will NEED lca, but it really depends on the coils you get, tire you choose, and amount you lower the car. Some guys do not need them, and some do.
Anyway, you should read through the meaty tire thread. It is THE thread for this size of wheel.
http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES!
Old 05-19-2018, 09:30 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
One "needs" rear lca if one needs rear camber adjustment.
Common cases are if one needs performance oriented alignment, if one wishes to change handling for specific result, if resulting camber is too different side to side, if one wishes to dial back negative camber from lowering to stock values. Well, and if specific camber is needed for wide tire/wheel clearance.
If it fits none of the above cases, of course there is no need adding adjustability feature in way of aftermarket adjustable rear LCAs. I find that adding camber adjustability is nice thing to have even for non tracked stock cars, as stock alignment can be rather uneven and alignment out of whack can impact handling in negative way even when daily driving. In cheapest form of front camberbolts + cheap LCA (like spc/whiteline/eibach) it's not THAT expensive.
Old 05-20-2018, 03:38 PM   #8
johl
johl's Avatar
Drives: toyota 86
I just fitted 255/35/18 to my wheels of the same specs you listed. Have a look in my build thread for pics but they fit fine and don’t rub on anything. I also fitted rear control arms and toe links to fix the rear camber when you go lower, however I’m only lowered about an inch
johl is offline   Reply With Quote
Old 05-20-2018, 09:48 PM   #9
Greenbean
Drives: 2017 series yellow BRZ
a 40 sidewall on an 18 inch is going to have a fitment issues a good bit of the time I'm on 18x9.5 +38 with a 255/35 tire and i think its the best fitment with no rubbing anywhere. if you dont mind rubbing then go 265/35
Greenbean is offline   Reply With Quote
Old 05-20-2018, 09:50 PM   #10
Greenbean
you can 255/35 up front too because hes going to get coilovers.
Looking for some help on fitment AnthonyArcaro Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-22-2018 07:28 PM
TRD Kit fitment Ds3ire Cosmetic Modification (Interior/Exterior/Lighting) 20 03-16-2016 03:11 PM
Help on Fitment! lxsedan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-07-2015 10:01 AM
XXR fitment help raven1231 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-01-2015 01:05 PM
Help with fitment BadLuckZN6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-24-2013 06:36 PM
