Drives: 2014 White Subaru BRZ Limited
Looking for some help on fitment
Currently I am running Eibach (82105140) Performance Spring Pro-Kit, which lowered the car roughly 1-1.5" all around with the stock strut. Recently I purchased 18x8 +35 wheels and 245x45x18 tires. However now that I have the tires next to my car they look MASSIVE.
I was doing some research and some people say to go with a 245x35x18 or a 235x35x18. What would any of you recommend for good clearance because I do not want to have to worry about rubbing or rolling my fenders? Anyone have experience with running this setup with the same or similar suspension geometry?Thank you, Anthony
Daily 2014 Satin White Pearl BRZ Limited
Instagram: @subyota |
245/35 18 would probably be closer to stock circumference. I mean if you're not currently rubbing on 245/45 18, you're not going to rub on 245/35 18.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
Well I haven't gotten the tires mounted on the wheels yet thats my main concern is wasting the time and money to mount tires only for them not to fit.
It shouldn't rub.
Country Boy 4 Life
my $0.02
i had 245/35/18 on my 18x8 front wheels to match the rear tires on my 18x9s. but after driving on them , they were too wide. i took them off and got 225/40 on the fronts. now the steering is better. lighter, more precise. im running MPSS tires. and have eibach prokit spring too. id suggest getting 225/40 on the 18x8 wheels. they will fit great at +35 offset and the tires are much cheaper!
I LIKE TIRES! |
#6 | |
Drives: '23 BRZ
Also be sure to pick a good tire make/model for your wants/needs and usage envelope. And check actual measured performance data at tirerack.com to be sure you don't get a crappy-performing tire. |
#7 | |
#8 | |
Drives: '23 BRZ
https://www.tirerack.com/tires/tests...y.jsp?ttid=222 |
#9 | |
#10 | |
Drives: 2015 Firestorm FRS
What wheels did you buy?
| TRD Kit fitment | Ds3ire | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 03-16-2016 03:11 PM |
| Help on Fitment! | lxsedan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-07-2015 10:01 AM |
| XXR fitment help | raven1231 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 04-01-2015 01:05 PM |
| 18x9.5 +45 fitment | Wilson15 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 10-05-2014 07:49 PM |
| Help with fitment | BadLuckZN6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-24-2013 06:36 PM |
