Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-08-2012, 02:58 PM   #1
eleu2166
Drives: '07 Civic Type R
Slimline Plates Plate Bracket
Posting this in its own thread as it seems to be lost in the other thread.
Here are some renders of an early prototype of a bracket for slimline plates.
With plate:
Without plate:
Different view with plate:
Different view without plate:
Right profile view:
The goal was to create an OEM looking plate bracket that also acted as a frame for the plate. So as you can see the design itself is based on the OEM bracket, matching the exact body contours/curvatures of the car.
It will bolt directly onto the existing holes without any modifications required. We've also tried to cover up the bottom two holes (inside the grille) from the OEM bracket, however, if someone who already has the car can remove their plate and bracket and take a picture we can then be certain we have successfully done so.
Anyways, we're still not sure whether we'll put these into production, let us know how many of you guys will be interested in possibly buying one of these and we can probably work something out.
Update (9/7/12):
We'll most likely be producing two versions in the following sizes:
  • 372x100mm (Fits all slimline plates in all states)
  • 372x84mm (Fits NSW premium metallic, coloured and white plates, also the smaller custom SA slimline plates as well)
We've picked these sizes as they cater for most if not all slimline plates across Australia.
eleu2166 is offline   Reply With Quote
Old 07-08-2012, 05:42 PM   #2
Z86
Drives: 86 GTS Auto in Pegasus White
Possibly interested. What price (ballpark), and what dimension for the plate?
Z86 is offline   Reply With Quote
Old 07-08-2012, 05:47 PM   #3
Nardi330
Nardi330's Avatar
Drives: 86
What size will it be?
I think NSW has a smaller slimline plate than QLD and our plate won't fit if this is made for NSW plate.
Nardi330 is offline   Reply With Quote
Old 07-08-2012, 06:07 PM   #4
Nambo
Nambo's Avatar
Drives: '12 BRZ [CBS]
+1
Although must be compatiable with Victorian slimline plates.
Nambo is offline   Reply With Quote
Old 07-08-2012, 07:40 PM   #5
eckoflyte
Drives: Toyota 86 GTS
ill definitely be interested in this. +1.
eckoflyte is offline   Reply With Quote
Old 07-08-2012, 09:02 PM   #6
eleu2166
We can produce them in any dimensions if we get the necessary numbers for each size.
In terms of pricing, we're working on the cheapest possible pricing without sacrificing quality. Will keep you guys posted.
We might also be looking into producing some carbon fibre ones as well.
Old 07-08-2012, 09:17 PM   #7
Sutty
Sutty's Avatar
Drives: Sonic Blue 86 GTS 6AT
Interested for Qld slimline plates.
Sutty is offline   Reply With Quote
Old 07-08-2012, 09:25 PM   #8
sticky
sticky's Avatar
Drives: 86 GTS 6AT
If you can price it <$100 I would be interested.
sticky is offline   Reply With Quote
Old 07-08-2012, 11:08 PM   #9
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
How many would you need to do a run on a perticular size?
I have a different size plate wouldn't mind an OEM looking holder for it.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 07-09-2012, 01:29 AM   #10
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
Also would be keen for a slimiline plate holder for QLD size. Pending price/quality obviously
Nafe is offline   Reply With Quote
Old 07-09-2012, 01:31 AM   #11
crimespree
Drives: 86
Same
crimespree is offline   Reply With Quote
Old 07-09-2012, 02:11 AM   #12
Sutty
Sutty's Avatar
Here's a rough idea of different plate sizes for different states. In general a slimline plate is 372mm x 100mm but as you can see there are also plenty of variations on that.
Australian Capital Territory.
Standard vehicle plates (same size front & rear):
1/2 size, 3 characters max are 133mm high x 190mm wide
3/4 size, 5 characters max are 133mm high x 317mm wide
Full size, 7 characters max are 133mm high x 372mm wide
Slimline plates (Front of vehicle only):
1/2 size, 3 characters max are 100mm high x 190mm wide
3/4 size, 5 characters max are 100mm high x 317mm wide
Full size, 7 characters max are 100mm high x 372mm wide
New South Wales.
Prestige Plates (Acrylic Plates with Aluminium Frames):
95mm high x 372mm wide.
Premium Metallic Plates:
84mm high x 372mm wide (front), 107mm high x 372mm wide (back)
Euro Plates:
White Euro Front and Back: 110mm high x 520mm wide
Black Euro Front: 84mm high x 372mm wide, Back: 110mm high x 520mm wide
Euro "Icon" Front: 84mm high x 372mm wide, Back: 110mm high x 520mm wide
Themed Plates:
134mm high x 372mm wide
Colourful Choice Plates:
White Plates:
Custom Yellow and Black Plates:
Varies depending on chosen content. Front and back maximum size: 134mm high x 372mm wide
Yellow Plates:
Northern Territory.
Standard plates:
372mm wide x 133mm high
Medium plates:
315mm wide x 133mm high
Small plates:
190mm wide x 133mm high
Slim Line plates:
372mm wide x 100mm high
Combination Slim and Standard plates:
372mm wide x 100mm high (front), 372mm wide x 133mm high (rear)
Queensland.
Standard plates:
372mm wide x 134mm high
Slimline plates:
US Size plates:
300mm wide x 152mm high
Slimline Euro plates:
Classic Euro plates:
520mm wide x 112mm high
2 x 2 Flexi plates (Acrylic):
Standard - 291mm wide x 135mm high
Slimline - 291mm wide x 100mm high
Standard - 372mm wide x 135mm high
Slimline - 372mm wide x 100mm high
Prestige plates (Acrylic Plates with Aluminium Frames):
Standard size - 372mm wide x 135mm high
Slimline size - 372mm wide x 100mm high
South Australia.
For more details visit this link.
Standard plates:
Standard: 371mm wide x 133mm high
Slim: 371mm wide x 100mm high
Custom plates:
Standard: 371mm wide x 106mm high
Slim: 371mm wide x 83mm high
Square: 300mm wide x 150mm high
Personalised plates:
Premium plates:
Euro plates:
Tasmania.
Standard plates:
Slimline plates:
Euro plates:
522mm wide x 114mm high
Victoria.
Custom Plates:
Standard size plates (3 to 6 characters) are 372mm wide x 132mm high
Slimline plates (6 characters) are 372mm wide x 100mm high
Slimline plates (5 characters) are 315mm wide x 100mm high
Slimline plates (3 or 4 characters) are 250mm wide x 100mm high
Euro Plates:
Standard Euro Plates are 520mm wide and 112mm high.
Mini Euro Plates are 372mm wide and 100mm high.
Signature Plates:
Standard Signature Plates are 255mm wide x 137mm high
Slimline Signature Plates: are 255mm wide x 105mm high
Grand Prix Plates:
Standard plates are 380mm long x 140mm high.
Slimline plates are 380 mm long x 106mm high.
Footy Plates:
Standard size only available 372mm x 132mm
Heritage Plates:
One Digit Heritage Plates are 197mm wide x 114mm high
Two Digit Heritage Plates are 203mm wide x 114mm high
Three Digit Heritage Plates are 228mm wide x 114mm high
Four Digit Heritage Plates are 338mm wide x 114mm high
Five Digit Heritage Plates are 406mm wide x 114mm high
Six Digit Heritage Plates are 456mm wide x 114mm high
Western Australia.
Custom Plates:
Slimline aluminium & polycarbonate are 372mm wide x 100mm high
1/2 size aluminium & polycarbonate are 190mm wide x 134mm high
3/4 size aluminium & polycarbonate are 315mm wide x 134mm high
Normal size aluminium are 372mm wide x 134mm high
Normal size polycarbonate are 375mm wide x 134mm high
Slimline series:
Slim line aluminium - 372mm wide x 100mm high
Retro and Blue plates:
Standard front and back are 372mm wide x 134mm high
Slim line front and back are 372mm wide x 100mm high
Slim line front is 372mm wide x 100mm and standard rear is 372mm wide x 134mm high
Corporate fleet plates:
This plate series is only available in 372mm wide x 134mm high
Europlates:
The europlate measures 520mm wide x 111.8mm high
Old 07-09-2012, 03:07 AM   #13
Panman
Panman's Avatar
Drives: 86 GTS
Lakin Plates here: http://www.lakinplates.com.au/index....54_107_767_768
Already does a plate holder specifically for the 86 and if you tell them plates you are putting on, they can even do the right plate covers for them (I've ordered mine for QLD slimlines).
Panman is offline   Reply With Quote
Old 07-09-2012, 03:15 AM   #14
Sutty
Sutty's Avatar
The only problem with the Lakin plate is that at the moment it is not shaped like the OEM model fitted to the car and doesn't mould around the bumper, the bottom of the plate has two legs on it that fasten in to the two lower bolts holes in the grill.
Grimspeed Tag bracket on dgm Coastermikey BRZ First-Gen (2012+) — General Topics 19 06-25-2012 06:54 PM
AMT rear sway bar bracket adamturbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-13-2012 11:06 AM
2013 BRZ License Plate Bracket Kit Installation Revision‏ taosracer Cosmetic Modification (Interior/Exterior/Lighting) 19 05-26-2012 02:28 PM
CUSTOM PLATES OR REGUALR PLATES? Koomoo Scion FR-S / Toyota 86 GT86 General Forum 13 05-21-2012 09:38 PM
