Old 05-13-2018, 09:12 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Tilton master clutch
What have you guys done to use this master clutch? The rod does not have the same thread as the stock one.
Old 05-13-2018, 10:19 AM   #2
gtpvette
Drives: 2015 FRS - FFR GTM
I drilled mine out and welded a new correct sized nut on the inside.
http://www.ft86club.com/forums/showt...is#post2972448
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 05-13-2018, 05:00 PM   #3
wrxdriver2002
Drives: 2015 Subaru BRZ
I ordered a new clevis with the correct thread. I got it from Www.pegasusautoracing.com
https://www.pegasusautoracing.com/pr...sp?RecID=10263
https://www.pegasusautoracing.com/pr...p?Product=3555
Clevis is first link and a longer rod is the second link. The stock rod that comes with the master cylinder was not long enough for my application. The 6.2 was too long so I shortened it to where it needed to be.
wrxdriver2002 is offline   Reply With Quote
Old 05-13-2018, 11:07 PM   #4
Sportsguy83
Drives: Limited BRZ
Perfect I’ll go this rout thanks!
Old 05-15-2018, 01:52 PM   #5
Sportsguy83
Drives: Limited BRZ
Did you get a master rebuild kit in order to replace the rod or since it was all brand new you just cut the longer rod and replaced it?
Old 05-17-2018, 09:34 PM   #6
wrxdriver2002
I just took it apart and replaced it. It wasn’t destructive to any component to replace. It was also really easy.
Any clutch master cylinder options that are more compact? Clash0901 Engine, Exhaust, Transmission 3 07-22-2018 06:32 PM
Clutch Master FX400 Disengagement issues? deedz Forced Induction 15 08-13-2016 09:42 PM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 04:48 PM
Clutch master stage4 anyone Djen Engine, Exhaust, Transmission 24 08-13-2013 05:42 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
