Old 05-23-2015, 04:38 PM   #1
nickw14
Drives: Built FA20
Crazy high LTFT, lean codes, e85...
Hey guys. So I am running the OFT e85 tune for the stock fuel system. My LTFT has always been somewhat high, but it usually stays below 20% at idle. I had a little trouble running lean at idle so I changed the AFR tables to bring the AFR down to about 13.5/14.0 (it fluctuates).
Thursday evening I was sitting in my car and the engine light and trac light came on. I checked the code and it was P0171 (lean). I started watching the AFR and it hovered around 15-15.5. But LTFT was all the way up to 38%! This does not seem right...
My first guess was that the ethanol mixes in my area changed from their winter to summer mix and the tune is just trying to account for the change in e%. Needless to say, I will probably go back to 93 for a while after this tank is empty.
nickw14 is offline   Reply With Quote
Old 05-23-2015, 04:47 PM   #2
phrosty
What do your fuel trims look like on 93?
On a healthy car, positive fuel trims of 38% would seem to indicate much higher than 85% ethanol content...
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 05-23-2015, 04:58 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
you verified the tune on your car?
Plug in the OFT and go to tunes, and the little " * " will be next to the tune thats currently written
Old 05-23-2015, 05:34 PM   #4
nickw14
Drives: Built FA20
I didn't pay too much attention to the fuel trims on 93.
I am on the correct tune, yes.
Old 05-23-2015, 06:02 PM   #5
steve99
Fuel trims that high indicate
1 you running a petrol tune on E85
2. you have intake or exhaust leak
3. you have aftermarket intake that needs maf rescaled.
4. damaged o2sensor ot maf sensor.
Old 05-23-2015, 06:07 PM   #6
nickw14
Drives: Built FA20
2 and 4 sound the most likely. According to the maf rescale thread, I should not rescale when using e85. I do have an aftermarket exhaust but I've had that for a few weeks now with no issues.
Old 05-23-2015, 06:31 PM   #7
steve99
if the fuel trims are high at idle and low rpm and ok midrange and higher then that usually indicates leak somewhere
is your intake stock ?
Old 05-23-2015, 10:20 PM   #8
nickw14
Drives: Built FA20
No, I have a k&n intake.
I will check my exhaust for leaks when I get a chance.
Old 05-23-2015, 10:44 PM   #9
steve99
I have not scaled k&n intake so not sure how off the maf scaling is
if its the one linked below then i would say the intake is the problem, it has the maf sensor way to close to throttle body and its unlikely it has air straightner like stock intake, it likey to have bad turbulant flow arroind maf sensor throwing off maf scaling and making it difficult to scale.
i recomend you put stock intake back in and just get a drop in filter for stock intake
http://www.knfilters.com/mobile/mPro...prod=69-8619TS
if you have a look at any logs you did on petrol will tell you if maf scaling is off, i suspect the intake may be your issue.
you can scale on e85 its just more complex due changing e%.
Old 06-15-2015, 03:44 PM   #10
gonzo
Drives: frs
When I had a similar issue (lean and etc. codes, high ltft+stft, lowered iam) my car wouldnt start a few days later. Turned out it was a dead battery. Replaced it and everything went back to normal. Maybe you should add a "5. your battery is dying"
gonzo is offline   Reply With Quote
Old 06-15-2015, 04:15 PM   #11
phrosty
A dud battery would not cause high fuel trims.
Old 06-16-2015, 07:58 PM   #12
aagun
Drives: 86
back to 93
install oem intake
reset ur rom
check ur ltft and stft
if still high then check ur DI failure coils , and replace the one or replace all ur DI . and then be sure u do not have kcfb while drive , i u do retard ur ignition map
aagun is offline   Reply With Quote
Old 06-17-2015, 10:53 AM   #13
DarkSunrise
DarkSunrise's Avatar
Could a high negative LTFT be caused by an exhaust leak at the header? I've been seeing about -6.xx to -7.xx at idle recently. From what I understand, exhaust leaks usually cause positive LTFT's at idle (pre-02 sensor leak allows fresh air in).
I think I can hear a slight leak at light loads, but would have expected to see positive LTFT's which is why I'm perplexed.
2022 BRZ Build
2013 FR-S Build
Old 06-17-2015, 11:59 AM   #14
phrosty
A healthy car will see trims fluctuate somewhat at idle due to highly variable intake temps. You might not have anything to worry about.
LTFT increased over 10% after oil change (new E85 user) tracerit Software Tuning 19 05-21-2015 04:35 PM
lean at idle only woode Forced Induction 5 05-03-2014 04:48 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 03:33 PM
