Drives: Car
Tire Recommendation
Hi,
I am looking for a tire recommendation for stock BRZ size. I prioritize the following 3 characteristics: Fuel Economy, Cheap, Hydroplane resistance. I don't care about dry grip and performance. I know the highly rated ones are MPSS or other "good tires" but they do not fit the first 2 characteristics I am looking for. Does any one ahve any recommendations? |
#2 | |
Country Boy 4 Life
I assume your stock tires are done. These are a good tire, are insanely cheap after the rebate, and the shipping is free! They are a summer tire with 300 treadwear. There are cheaper A/S tires on tirerack, if you want to go that direction. https://www.tirerack.com/tires/tires...omCompare1=yes
I LIKE TIRES! |
Drives: 2015 BRZ
Based on your criteria a good All-Season tire will be best for you. Check out the Michelin Pilot Sport A/S 3s or the BFGoodrich G-Force Comp 2 A/S.
#4 | |
Country Boy 4 Life
Those are great tires! But, AS3's are only $10 cheaper for a set than the MPSS, So I don't think that fits OP's criteria. The BFG is $500 for a set. I made my suggestion, because they are $283 for a set, OP didn't mention cold just wet conditions, and because a good summer also works in rain. And because the A/S Sumitomo is only $10 less per set.
I LIKE TIRES! |
Both good choices. Not sure if they meet the "cheap" criteria though. Michelin does usually have rebates that can reduce the price from "You want how much?" to "OK I can live with that". I think I got an $80 a set rebate when got mine.
#6 | |
#7 | |
Country Boy 4 Life
True. I didn't look at his location. Just his search criteria (budget) I have experience with the A/S Michelin, MPSS, BFG Sport Comp 2 A/S, and Sumitomo HTRZ III. The Sumitomo HTRZ III, is a great tire for the money paid. I do not have experience with cheap A/S tires. I didn't want to suggest a tire that I do not have first hand experience with. It sounds like OP wants LRR tires, except that they are expensive...
I LIKE TIRES! |
Drives: 2015 BRZ
True, you guys are right i guess everyone has a different meaning of cheap lol. I think the G-Force Comp are definitely priced well its a good proven tire. OP dont cheap out on tires its worth the cost to get a good tire
#9 | |
#10 | |
Drives: 2013 Scion FRS
#11 |
Wasn't gonna be the guy that said it but... This ^^^
#12 |
Drives: 2019 BMW ///M4
I have the Michelin Pilot Sport A/3+. Pretty pricey but it’s a performance tire. MPG dropped around 2 MPG when I switched from stock. Treadlife isn’t as great as stock. 23,000 miles out of 45,000 and they are done. I would get the Michelin Premiere AS since you want a good tire but not focused base. The premier AS has this technology as when it gets worn, it still safe for wet because new grooves appear.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#13 |
Drives: 2018 BRZ Limited, 2017 Sportage
I have 4 Michelin Primacy HP's pulled from my new BRZ with zero miles on them. If you were in Vegas, you could have all four of them for $250 total. Yeah, I know everyone calls them Prius tires, but if you have a daily driver, they are really quite good....
#14 |
With your requested criteria, Buy stock tires that others have removed!!!!!!!!!!!
| Tire recommendation | EzyBrzy | Northern California | 30 | 03-31-2018 09:16 PM |
| Summer Tire Recommendation | Is Always Angry | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 07-23-2017 05:22 PM |
| Tire recommendation help | Davesta619 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 10-21-2016 06:32 PM |
| Las Vegas: Tire recommendation | buruguduy | Southwest | 6 | 01-08-2016 03:03 AM |
| Tire Size Recommendation! | Cvxne | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 05-04-2015 12:13 PM |
