Old 10-21-2016, 06:27 PM   #1
Davesta619
Drives: Brz
Tire recommendation help
I tried searching for my answer but there seems to be different opinions.
I'm trying to figure out the right tires for my 18.8.5 +32 lowered on RCE yellow springs. Just a DD, no track
I know the 3 options are
225/40/18 (I believe this stretches alittle)
235/40/18
245/40/18
Which one would you guys recommend?
Thanks for your time and help!
Davesta619 is offline   Reply With Quote
Old 10-21-2016, 06:46 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Get square ones
Old 10-21-2016, 07:01 PM   #3
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
It really matters on how you like the look of how the tire sits. 235 would be the best imo.
ExxelDistributions is offline   Reply With Quote
Old 10-21-2016, 07:04 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
245/35/18 will sit square on the 18x8.5 and be the same OD (outside Diameter) as the stock tires. This keeps the speedo accurate.
http://www.ft86club.com/forums/showthread.php?t=88804
Here is a link to a car that has RCE yellows and 18x8.5 +35 (3mm sunk in compared to your wheels) and 235/40/tires. After seeing this I would either get 225/40 or 245/35. Depending on if you want a slight stretch or not.
Thread shows 18x8.5 with 225/40
http://www.ft86club.com/forums/showthread.php?t=65630
You will need camber bolts. (you actually can install two sets, top and bottom, to get more camber if you need it) Plus, the bolts are cheap.
All the sizes you listed have a bigger OD.
Stock OD =24.62"
245/35/18=24.75"
225/40/18=25.09"
235/40/18=25.4"
Tire weights: MPSS tires, specs from TireRack
215/45/17=21lbs
245/35/18=23lbs
225/40/18=22lbs
235/40/18=23lbs
Tire calc. It helps!
http://www.discounttire.com/dtcs/infoTireMath.do
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Davesta619 (10-21-2016), go_a_way1 (10-22-2016)
Old 10-21-2016, 07:17 PM   #5
Davesta619
Drives: Brz
Stock OD =24.62"
245/35/18=24.75"
225/40/18=25.09"
235/40/18=25.4"
215/45/17=21lbs
245/35/18=23lbs
225/40/18=22lbs
235/40/18=23lbs
This is great info! Thanks a lot. Sounds like 245/35/18 is the logical choice. I actually came across that first link of the car on RCE yesterday while trying to find my answer haha.
The Following User Says Thank You to Davesta619 For This Useful Post:
Leonardo (10-22-2016)
Old 10-21-2016, 07:32 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
No problem! Here is a link that shows 18x8.5 +33 (so close) Prokit spring (mild drop like RCE) and 245/35/18 tires POST#25
http://www.ft86club.com/forums/showthread.php?p=1215664
Good Luck!
Edit: wanted to find this two posts ago... LOL
235/40-17 summer tire recommendation? Pat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 02-22-2016 05:33 PM
Las Vegas: Tire recommendation buruguduy Southwest 6 01-08-2016 04:03 AM
Tire Recommendation - 18x8.5, Stock Ride Height Quasar Kid Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-13-2015 07:38 PM
Tire Size Recommendation! Cvxne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 05-04-2015 01:13 PM
Tire/Wheel or auto shop recommendation in Seattle area please. mugen79 Northwest 6 12-04-2012 01:13 PM
