Old 04-28-2018, 03:00 PM   #1
iBrian
iBrian's Avatar
Super sensitive steering?
Hey everyone, just picked up a 2014 BRZ Limited w/24k miles on it a few days ago. I've got a bit of a concern and thought I might have the answer but just found out that wasn't the case.
Under hard acceleration, approaching higher speeds 70+ the front end feels super unstable, almost like i'm unable to keep the car in a straight line. I took it in to have the alignment and toe checked and both came back spot on. The car is entirely stock and they checked underneath and didn't see any signs of damage or wear. Cruising at 80+mph I can literally tap the steering in one direction and the car jerks hard. Is this common with the BRZ/FRS?
Does anyone have any suggestions or recommendations? Thanks for the help in advance.
iBrian is offline   Reply With Quote
Old 04-28-2018, 03:04 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It's a sports car with quick ratio steering. What kind of car are you coming from?
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Tcoat (04-28-2018)
Old 04-28-2018, 03:23 PM   #3
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
It's best used for when people on the highway are just perfectly spaced out so you cannot pass, but because you're driving a twin then you can just insert yourself in between them with a quick jerk of the wheel.
carsebuco is offline   Reply With Quote
Old 04-28-2018, 05:42 PM   #4
ryoma
ryoma's Avatar
what exactly is "spot on" for your alignment? AFAIK, the OEM alignment is a wide range.
The Following 2 Users Say Thank You to ryoma For This Useful Post:
guybo (05-18-2018), strat61caster (04-28-2018)
Old 04-28-2018, 06:11 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Not sure exactly what your version of a tap is. Like others said if your new to this cheap sports car then it gets some getting used to.
I would suggest you ask the mechanic drive it at the same speeds. That way they can identify the problem, if any.
The Following User Says Thank You to Mr.ac For This Useful Post:
ToySub1946 (04-28-2018)
Old 04-28-2018, 06:51 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
OP, what are your tire pressures?
The Following User Says Thank You to Spuds For This Useful Post:
krayzie (04-28-2018)
Old 04-28-2018, 07:29 PM   #7
iBrian
iBrian's Avatar
Focus ST, lol. i'm used to torque steer.
Old 04-28-2018, 07:30 PM   #8
iBrian
iBrian's Avatar
i can take my pinky, put it on the bottom of the steering wheel, barely flinch it and the steering responds like I put a lot of input into it.
Old 04-28-2018, 07:31 PM   #9
iBrian
iBrian's Avatar
I honestly didn't think to actually check, tire shop said they were good and it just slipped my mind, i'll go out and check it in just a few moments.
Old 04-28-2018, 08:14 PM   #10
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Stock tires? Probably not right cuz of the year and mileage of the car.
Did you get a printout from the alignment tech? I wonder what's your caster.
krayzie is offline   Reply With Quote
Old 04-28-2018, 08:27 PM   #11
Greenbean
Drives: 2017 series yellow BRZ
I love how you say "cheap" sports as if the steering is bad. Literally the most liked thing about the twins is the steering response and feel.
Greenbean is offline   Reply With Quote
The Following User Says Thank You to Greenbean For This Useful Post:
arkanist (04-30-2018)
Old 04-28-2018, 08:27 PM   #12
Need to find the guy on here that said he was developing an injury because his steering was so stiff and trade cars!
The Following 9 Users Say Thank You to Tcoat For This Useful Post:
bkharmony (04-30-2018), chaoskaze (05-01-2018), extrashaky (04-28-2018), HKz (04-30-2018), johan (04-29-2018), new2subaru (04-28-2018), spike021 (04-29-2018), Spuds (04-28-2018), Ultramaroon (04-28-2018)
Old 04-28-2018, 08:34 PM   #13
Brink
Drives: 2017 BRZ
http://www.ft86club.com/forums/showthread.php?t=125098
Brink is offline   Reply With Quote
The Following 3 Users Say Thank You to Brink For This Useful Post:
chaoskaze (05-01-2018), Spuds (04-28-2018), Tcoat (04-28-2018)
Old 04-28-2018, 09:01 PM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
When I first took my twin on the highway it felt to me like it drifted off course very easily. Turns out it was just the effect of a short wheelbase, sensitive steering ratio (13.2:1 If I recall, identical to the STI) and possibly combined with RWD. Mechanic test drive necessary.
The Following User Says Thank You to wbradley For This Useful Post:
OfficeWorker (04-30-2018)
Too Sensitive? euthqt Scion FR-S / Toyota 86 GT86 General Forum 50 03-02-2016 10:05 AM
Blank Carbon Fiber Steering Wheel Limited Super Sales!! Dctmotorsports CANADIAN Sales 2 11-23-2015 08:16 PM
Blank Carbon Fiber Steering Wheel Limited Super Sales!! Dctmotorsports Interior Parts (Incl. Lighting) 4 11-18-2015 12:58 PM
FR-S may be very sensitive to bad gas. FRiSson Scion FR-S / Toyota 86 GT86 General Forum 49 02-14-2014 11:54 PM
