Drives: 2017 BRZ WR blue PP
Transmission chattering after switching to motul gear300
Switched to motul gear 300 last week, everything is fine except there is a chattering noise when in neutral and clutch is not pressed. It had never happened before fluid change. I'm fine with the noise since it only occurs in neutral, just afraid that my transmission would be damaged.
![]() Thank you for any input.
Only happy when it rains.
Drives: series.blue
give the fluid time, it needs to 'break in' a little. Sounds weird, but the transmission will be much better.
| Motul Gear Competition 75W-140 in Transmission and Diff | JBezugs | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 03-18-2018 06:07 PM |
| Motul Gear Competition 75W-140 in Transmission and Diff | JBezugs | Engine, Exhaust, Transmission | 6 | 03-15-2018 04:55 PM |
| Can I use Motul 300ls on transmission and differential | Argento86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 08-08-2014 07:52 PM |
| Motul Gear300 75W90 oil change interval? | levinchow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-09-2014 12:20 PM |
| Motul Gear300 75w90 and brake fluid | JoeBoxer | Mechanical Maintenance and Tools | 5 | 07-06-2013 11:01 PM |
