CANADA Canada
Old 07-25-2012, 11:58 AM   #1
RoryTate
Drives: 2013 Subaru BRZ
TPMS and Canadian vehicles
Hey guys,
I inquired with the dealer if the Candian spec BRZs have TPMS sensors or not. The response was not 100% certain, but the indication is no.
Can anyone verify 100% that there are no TPMS sensors on Canadian BRZs?
RoryTate is offline   Reply With Quote
Old 07-25-2012, 12:14 PM   #2
engsr
Drives: Subaru BRZ
I'm fairly certain that my BRZ doesn't have it - no light on the dash, the valves on the wheels are the standard rubber ones.
Bryan.
engsr is offline   Reply With Quote
Old 07-25-2012, 12:23 PM   #3
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
really? i thought these became standard safety equipment on all new cars a while back
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 07-25-2012, 12:43 PM   #4
stateless
Double Dragon
stateless's Avatar
Drives: 2013 6MT BRZ Limited
I was under the impression that it came with TPMS and that it was mandatory, but I just checked https://canadasafetycouncil.org/node/895 and apparently it's not mandatory in Canada. That's cool if our BRZs don't have them, should save some money when I buy winters.
stateless is offline   Reply With Quote
Old 07-25-2012, 12:46 PM   #5
Dragon86
Drives: Whiteout FR-S MT
I think they are on the FR-S, and nothing in the BR-Z. Also i thought that these basic saftey feature should be standard, but i guess not.
Dragon86 is offline   Reply With Quote
Old 07-25-2012, 01:41 PM   #6
Reason
Reason's Avatar
Drives: Whiteout 6MT FR-S; E30 BMW's
I can confirm they are on the FR-S in Canada, I had a puncture last week and the TPMS alerted me to it.
I will say I was grateful for that. I picked up a screw and would have come out to a flat tire in the morning so it saved me a headache.
Still would rather not have it, but I'll live with it.
Reason is offline   Reply With Quote
Old 07-25-2012, 02:58 PM   #7
abitolder
Drives: 2013 FRS Argento MT
What it means is that if you move to the USA you cannot take the Canadian sold BRZ with you as it does not have TPMS which is required after Sept 1 2007 for 2008 models, it is almost impossible to retrofit. FRS should be OK as it does have TPMS, might be worth considering if you are purchasing and considering a job change down the road!
abitolder is offline   Reply With Quote
Old 07-25-2012, 04:38 PM   #8
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Interesting. This means the TPMS must be easy to turn off via flash if Subaru Canada was able to have it done. I was hoping the FR-S wouldn't have it but alas.
Khyron686 is offline   Reply With Quote
Old 07-25-2012, 09:14 PM   #9
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Good to know, thanks!
Rossman is offline   Reply With Quote
Old 07-25-2012, 09:49 PM   #10
Stav
Stav's Avatar
Drives: 13' FR-S Argento,74' Alfa GTV
Damn, new wheels go on tomorrow... anyone know how much dealership sells TPMS for? Is it in valve stem or is it inside wheel?
Stav is offline   Reply With Quote
Old 07-25-2012, 10:26 PM   #11
Khyron686
Valve stem, they are at least 60-100 each, AND you need to go to the dealer to "program" which set of sensors the car should watch.
Or you can follow the DIY to put tape over the light and never see it again. It does NOT stop you from turning off VSC/Trac unlike some cars...
I'm just going to move mine to the new wheels and not have sensors in the winter tires. Then wait for new sensors that allow you to clone your existing ones (then you can switch back and forth and the car won't care which set is on).
Old 07-25-2012, 10:58 PM   #12
rL-gT
Drives: Lexus IS300 / Lexus IS250 AWD
You can build a TPMS Pipe Bomb.
Use PVC Piping that is large enough to hold all 4 sensors, Put 2 Caps on it. 1 Which should have a Tire Valve. Seal it up with epoxy or w/e you can find to get a high pressure seal
Inflate the tube to 35 PSI. Set it and forget it somewhere in your car.
Its what us Lexus Guys Do lol.
PS. DO NOT USE AFTERMARKET SENSORS. They Dont work well at all.
rL-gT is offline   Reply With Quote
Old 07-25-2012, 10:59 PM   #13
ymboc
ymboc's Avatar
I know that's the case for many cars... are you sure its the case for the FR-S?
Mazdas for example are self-learning... I think (or I'd like to believe) that for cars that only have a 'dumb' warning light instead of a per-wheel pressure readout on the dash there's a good chance it will be self learning.
ymboc is offline   Reply With Quote
Old 07-25-2012, 11:04 PM   #14
dyim
dyim's Avatar
Drives: ?
Some 'TPMS' relies on the rolling diameter of the tires instead of actual sensors in each wheel.
Can you confirm which one you have please?
Thanks
dyim is offline   Reply With Quote
What other vehicles use a 5x100mm bolt pattern? EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 09-13-2014 04:42 AM
Incoming Vehicles available at Scion of Kirkland RogerCarr_TOK Northwest 14 08-04-2012 01:38 PM
Natural Gas Vehicles and Sportscars KaliKev Other Vehicles & General Automotive Discussions 11 04-28-2012 06:16 PM
TO ALL MY CANADIAN FRIENDS - BRZ Canadian Pricing Released zex BRZ First-Gen (2012+) — General Topics 7 04-24-2012 12:46 AM
