Old 04-17-2018, 03:02 PM   #1
Xbk47
Drives: 2016 BRZ
Hose size for bleeding brakes
I’m flushing my brakes soon and need to know what size hose I need to attaching to the brakes.
Anyone know the diameter to get?
Thanks,
Shawn
Xbk47 is offline   Reply With Quote
Old 04-17-2018, 03:06 PM   #2
wparsons
wparsons's Avatar
As long as it's flexible enough, I.D. isn't critical. I use large fuel tubing from a hobby store, it's usually about $1/foot and easy to source if you have a hobby store nearby that sells nitro cars/boats/planes/helis.
flickr
Old 04-17-2018, 04:48 PM   #3
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
I'd also like to know tubing size needed for draining brake fluid and draining coolant from the radiator. Are we talking 1/16" ID is even fine if it's flexible? 1/2"? 1"? Just a ballpark answer is needed so I can get something before I take stuff off the car to get at it.
I imagine 1/4" is fine (I have some clear tubing I bought for brewing beer) but I haven't found measurements of the barbs anywhere, so don't know if they're a lot smaller or bigger than I'm expecting.
EDIT: Didn't bother searching for the radiator one, so I looked and found 8mm, but the brake flush guides don't mention a specific size.
Horrid_Funk is offline   Reply With Quote
Old 04-18-2018, 08:09 AM   #4
markitect
Drives: Scion FRS
For brakes I use the clear fish tank air line tubing. it is flexible enough you can pop it on nice and snug.
markitect is offline   Reply With Quote
Old 04-18-2018, 08:26 AM   #5
Tokay444
Anti stance.
Tokay444's Avatar
Needs to fit on the barb of the bleeder.
Old 04-21-2018, 05:38 PM   #6
Xbk47
Drives: 2016 BRZ
5/16” ID is what I ended up using. 1/4” was a bit tight to go on.
Old 05-04-2019, 09:50 PM   #7
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Im doing my first flush next week, do you happen to remember what size flare nut wrench would be right for the job? (for the bleeder valve)
I think it is https://smile.amazon.com/ATE-706202-...omotive&sr=1-1 but Im not sure.
DandoX is offline   Reply With Quote
Old 05-04-2019, 10:30 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
10mm
Old 05-04-2019, 10:46 PM   #9
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
I've never used a flare nut wrench on the bleeder valve. The bleeder valve you can use a normal combo wrench on. The flare nut wrench is for the brake line fittings.
Tristor is offline   Reply With Quote
Old 05-05-2019, 12:09 AM   #10
maslin
Benz Tech
Drives: 2017 BRZ Premium
Bleeders have a tendency to round off, or worse yet, break off in the caliper. A good quality 6pt box end wrench is best if you have room to swing it.
Or break it loose with a 6pt socket, snug it back barely, the go at it with a combo wrench.
Shouldn’t have any space constraints with the wheels pulled off, I’m usually battling them from underneath with a rim right in the way. Mercedes get brakes bled every two years, we have a pressure bleeder running all day long.
maslin is offline   Reply With Quote
Old 05-06-2019, 10:51 AM   #11
wparsons
wparsons's Avatar
Yeah, no need for a flare nut wrench on the bleeder, there's no hard line on it stopping you from putting a box end wrench or socket over it.
I always use a socket to break it loose and an open end wrench to open/close while actually bleeding (when the rubber hose is on), then final tighten with the socket again.
flickr
Old 05-06-2019, 04:22 PM   #12
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Just flushed mine a couple weeks ago. 5/16" tube and 10mm wrench/socket.
I installed SpeedBleeders which are 11mm.
Muskoka800 is offline   Reply With Quote
Old 05-06-2019, 05:18 PM   #13
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Link where to buy the speedbleeders you installed? I'm not sure the size that our cars have. Thank you!
tintumz22 is offline   Reply With Quote
Old 05-06-2019, 11:33 PM   #14
Muskoka800
Speedbleeders
http://www.speedbleeder.com/
The type is SB1010 for our OEM calipers.
They come two in a package, so order two packs for a total of four bleeders. US$60.00
brake bleeding, air in abs? Grip Ronin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-22-2018 07:34 PM
Bleeding brakes-cycle ABS system? fasteddy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-11-2015 02:57 PM
Bleeding Air through TPMS GarStar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2015 02:14 PM
Addition of a radiator hose sensor temp adapter & coolant bleeding FutureFT86 Engine, Exhaust, Transmission 9 07-21-2014 11:50 PM
My Car is bleeding! Ec1990 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 04-01-2014 10:31 AM
