Drives: S2000
Knocking noise when releasing clutch
Hey guys, this is on a 2017 86 with only 500 miles on her. I can clearly hear a knocking noise when I release the clutch, especially when Im at a stop. Is this something normal, maybe I just need to break in the car more? Im coming from Hondas, and Im familiar with squeaky clutches, but never this kinda noise.
#2 | |
* released when not in gear? * released when the engine is running or not or both? Can you isolate where the sound is coming from (in the wheel well or from the clutch housing)? You might have the dealer give a listen since it's under warranty. These cars make some strange sounds ...... maybe it's just one of those. humfrz |
#3 | |
Drives: S2000
Didnt expect to go to the dealer so soon, but definitely making an appointment. Last edited by sfdai0; 04-15-2018 at 03:55 AM. |
#4 | |
I'm going to wake up our resident clutch expert @Ultramaroon for an opinion. Meanwhile, it wouldn't hurt to have the dealership check it out ...... although, they will most likely tell you it's "normal". humfrz |
not playing cards
I have my suspicions but, without a sound clip, I'd be completely guessing.
Sometimes the pedal cluster clicks. That can be annoying but harmless. There's some backlash in the driveline. That may also contribute, depending on the conditions.
Drives: S2000
well, like humfrz predicted, dealer said it was normal. They did let me try out a new 86 on their lot and it did have the same slight clicking noise. I guess the clutch on these emit noise. As long as it doesnt get worse, Im just gonna drive the car.
All clutches make noise, it's whether or not the car has enough insulation to mask the noise or not, this car has as little sound insulation as possible, the penalty you pay for having one of the lightest RWD cars on the market right now.
#8 | |
Drives: S2000
My S2000 and DC2 Type-R and even my civic never made a noise. But if some clicking noises are normal for these cars, Im fine. |
Drives: 2016 Subaru Brz
I've seen this posted somewhere. The Clunk when putting it in 1st from neutral is normal. It's the input shaft. To avoid this just press and hold the clutch pedal 1 full Mississipi second before putting it in 1st.
| Idle knocking noise | Kostamojen | Issues | Warranty | Recalls / TSB | 33 | 04-20-2018 01:09 PM |
| Pressing/releasing clutch pedal - audible click sound (not the clutchs switch | tanner | BRZ First-Gen (2012+) — General Topics | 26 | 06-03-2014 08:24 PM |
| Clunk sound after starting car and releasing clutch | subiestyle | Issues | Warranty | Recalls / TSB | 1 | 03-14-2014 02:30 AM |
| noise when releasing clutch | andrew5826 | Issues | Warranty | Recalls / TSB | 5 | 02-17-2014 06:41 PM |
| noise when releasing clutch/shift resistance | abutterman | Issues | Warranty | Recalls / TSB | 11 | 07-20-2013 09:23 AM |
