Old 04-13-2018, 08:56 PM   #1
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Loose Clutch Pedal
I was stripping the interior a few weeks and think I might have pulled on the wire behind the pedals. Everything is still connected but the clutch pedal is super loose I can’t even put it into gear. Can anyone help?
Carlitoz3 is offline   Reply With Quote
Old 04-13-2018, 09:41 PM   #2
humfrz
Well, first off the clutch system isn't electrical ....... it's an hydraulic system. So, no wires.
However, there is a spring up there that helps the clutch you may have disconnected or it's broken.
The rest of the system is hydraulic so if the pedal is all wonky the system may have lost fluid.
I'd suggest that you check the spring then check the fluid level in the clutch system.
humfrz
Old 04-14-2018, 12:41 AM   #3
dutchman1
Drives: 2017 86 6-Speed
Looking at the video, it looks to me like your clutch pedal is no longer connected to the clutch master cylinder, or the master cylinder is loose and moving when you press the pedal. Something is definitely mechanically wrong in there. Hydraulic issues would typically manifest themselves differently, and if your clutch assist spring was gone the pedal would just be a little stiff but otherwise behave the same.
Do some google research on how a hydraulic clutch works, they're pretty simple systems.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 04-14-2018, 12:49 AM   #4
My guess is that the the push rod pin has come out.
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Is anyone else's dead pedal loose/making noise? KevinR Issues | Warranty | Recalls / TSB 41 01-16-2017 12:33 PM
Gas pedal loose? nyfries Issues | Warranty | Recalls / TSB 7 01-02-2017 05:22 PM
clicky/loose brake pedal? nyfries Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-26-2014 10:59 PM
Gas pedal loose Enraged21 Issues | Warranty | Recalls / TSB 7 10-18-2013 02:18 PM
