Old 09-27-2012, 12:50 AM   #1
KevinR
Drives: 1993 Turbo Miata, 2013 Asphalt FR-S
Is anyone else's dead pedal loose/making noise?
Mine is loose and it pops when I put any sort of pressure on it. I'll take it to the dealership eventually, but I was curious if I was the only one. It's quite annoying, I dont need to put much pressure on it at all and it clicks/pops.
I should mention that I have 1600 miles on mine
KevinR is offline   Reply With Quote
The Following User Says Thank You to KevinR For This Useful Post:
Pkush (11-20-2014)
Old 09-27-2012, 12:56 AM   #2
whaap
whaap's Avatar
I don't quite have a thousand miles on mine yet but it is not a problem. I do drive with the back seat folded down and have a bothersome rattle in the area of the trunk floor but so far that's it for problems.
whaap is offline   Reply With Quote
Old 09-27-2012, 10:42 AM   #3
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Mine pops all the time (7000 miles), and I just picked up the rear deck pop, and a rattle from my washer stalk.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 09-27-2012, 10:53 AM   #4
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
I think I'm having a similar issue (more of a click than pop), but it's not bad enough to bother me... Yet.
If it becomes worse, I'll make sure to point it out at my first service visit. As of now, it seems so minor, that the service tech will likely have a difficult time spotting it (in my case).
Texas BRZ is offline   Reply With Quote
Old 09-27-2012, 10:55 AM   #5
CBR600RR
Drives: Raven Black
@Hawaiian ^washer stalk???
Old 09-27-2012, 10:13 PM   #6
leonwood
leonwood's Avatar
Drives: 86
mine does, when i step on it very hard and it felt loose at the top
leonwood is offline   Reply With Quote
Old 09-28-2012, 12:05 AM   #7
winter
winter's Avatar
Drives: Argento FR-S 6MT
I haven't heard this yet at all. 4400 mi.
winter is offline   Reply With Quote
Old 09-28-2012, 12:19 AM   #8
Hawaiian
That guy
Hawaiian's Avatar
Sorry, I wrote that on my phone. The windshield washer stalk/stick rattles. Most people would think it comes from their keys, but my frs key is solo.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 09-28-2012, 12:22 AM   #9
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I dont hear it making any noise, but I can feel it "popping" it I step on it a certain way. Not sure if I want to get new pedals from a vendor here or mention it to my dealer.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-28-2012, 12:32 AM   #10
CBR600RR
Drives: Raven Black
Hmmm. Mine doesnt.
Old 09-28-2012, 12:44 AM   #11
SLEEPER WRX
Wow, thanks for posting this
Mine's been loose since day 1
I just figured that when it pissed me off enough I'd get down there and tighten it up
SLEEPER WRX is offline   Reply With Quote
Old 09-28-2012, 07:41 AM   #12
roddy
roddy's Avatar
Drives: '13 Ultramarine
I had an annoying rattle in the same area. In my case it was the wiring harness for the reverse lights. It may not be the same for your car, but it is easy to check. From under the car, follow the harness from the reverse light housing to where it goes over the driver's side tailpipe. Right at this spot, there is a piece of plastic wire armor covering the harness (about 6" long) that was making intermittent contact with the body metal just below where the bumper bolts to the body. I stuck a 2" piece of foam tape between the body and that wire armor. Problem solved. I have fixed several rattles/buzzing sounds in this car and should get to writing up a DIY on them.
O.P., sorry I can't help you here. I haven't had an issue with the dead petal yet.
Old 09-28-2012, 09:05 AM   #13
djliquidsteele
Drives: Scion FR-S
Yup, I had the same problem. You kind of push on it hard and it squeaks. I'm a cyclist, so I popped off the dead pedal and took a small piece of bar tape I had laying around and put it under the dead pedal. Seems to have take care of the problem.
I also used bar tape to get rid of my door rattle. Versatile stuff.
djliquidsteele is offline   Reply With Quote
Old 09-29-2012, 12:26 AM   #14
nocurfew
nocurfew's Avatar
Drives: Whiteout FR-S
I have the same problem!
nocurfew is offline   Reply With Quote
Found Loose wire...?? IDK what it is rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 34 06-10-2020 01:42 PM
Red stitching is coming loose. Chip Issues | Warranty | Recalls / TSB 7 11-01-2012 11:02 AM
Fuel Lid Tight or Loose? JiB Issues | Warranty | Recalls / TSB 18 09-20-2012 01:50 PM
FR-S Stock Carpet Mats - anyone else's doing this? kramerica_industries Scion FR-S / Toyota 86 GT86 General Forum 27 08-24-2012 12:29 AM
Dead pedal height bqe-lie-fdr Scion FR-S / Toyota 86 GT86 General Forum 0 02-25-2012 09:21 AM
