Old 04-09-2018, 05:47 PM   #1
oppiee
Drives: 2014 Scion FRS (Red)
coilover install question
Hey guys,
I am planning on installing ohlins coilovers.
I understand that it is recommended to replace some of the oem bolts in the front and back. I cant seem to find it. Can you guys let me know which ones and part numbers?
Thanks
oppiee is offline   Reply With Quote
Old 04-09-2018, 07:05 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by oppiee View Post
Hey guys,
Thanks
Replace them for what reason?
Old 04-09-2018, 07:10 PM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I believe there are some suspension bolts that Subaru specifies to not re-use and to replace with new ones. Something about threads getting elongated and proper torque specs, yadda yadda.
Originally Posted by humfrz
I'm old and lazy
Old 04-09-2018, 07:24 PM   #4
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
subaru part numbers from https://parts.subaruonlineparts.com/...-h4-gas-engine
front
901000371 - strut upper bolt (x2: one for left and one for right)
901000394 - strut lower bolt (x2: one for left and one for right)
902380008 - strut nut (x4: 2 each for left and right)
rear
901000435 - strut bolt (x2: one for left and one for right)
902350032 - strut nut (x2: one for left and one for right)
i think i have the bags for toyota p/n's at home, but honestly i will probably forget to check
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 04-10-2018, 05:20 PM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
should be fine reusing them. they're not small bolts and nuts.
Old 04-10-2018, 05:33 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
There are a lot of fasteners that Toyota says are non-reusable. Here is one example.
Old 04-10-2018, 07:10 PM   #7
finch1750
finch1750's Avatar
WTF. Never knew that.
Wonder how many people actually do replace them lol
Old 04-10-2018, 07:30 PM   #8
asdf
asdf's Avatar
Drives: #0517
Probably almost nobody, lol.
Toyota did send me new bolts and nuts when I bought TRD springs, though!
R1 3 5
. 2 4 6
Old 04-10-2018, 08:06 PM   #9
Decep
Drives: 2013 FR-S Series 10
That is weird. They are torqued fairly tight so maybe they stretch a bit.
Old 04-10-2018, 08:41 PM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
A lot of times they are slightly crimped for safety. I'm sure you're ok, but some OCD people better by new.
Old 04-10-2018, 10:12 PM   #11
wparsons
wparsons's Avatar
The diagram only shows the nuts are non-reusable, not the bolts.
flickr
Old 04-10-2018, 10:19 PM   #12
norcalpb
norcalpb's Avatar
I’ve out 130lbs on those hub nuts several times now, maybe they assume people will use a 12pt head and chew it up over time?
Old 04-10-2018, 11:31 PM   #13
oppiee
Mine are rusty from the winter so I think might be better to get new
Old 04-15-2018, 10:05 AM   #14
oppiee
Would you guys replace the bolt on the endlink?
Help w/ Coilover Install Waffle86 Northwest 15 09-12-2017 04:47 PM
Coilover install JerryMichaels7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-05-2014 03:31 PM
Quick Question about Doing coilover install Xdragonxb0i DIY (Do-It-Yourself) Guides 3 05-31-2013 02:14 PM
HKS Coilover install gtauto AUSTRALIA 16 04-21-2013 07:37 AM
Suspension (Coilover) Install Question crizkay Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 02-28-2013 09:17 AM
