Old 04-07-2018, 03:02 PM   #1
gpvecchi
gpvecchi's Avatar
Camber bolts, what's the truth?
Searching on the internet I found conflicting opinions.
Never put a camber bolt on top hole on front, there's slip risk!
Never put a camber bolt on bottom hole, there's breaking risk!
So, what's the truth? Eibach and SPC sell bottom 14mm camber bolts, Whiteline sells 16 mm upper bolt...
gpvecchi is offline   Reply With Quote
Old 04-07-2018, 04:02 PM   #2
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Stuff breaks and stuff slips. Inspect often.
The Following User Says Thank You to EAGLE5 For This Useful Post:
strat61caster (04-07-2018)
Old 04-07-2018, 04:16 PM   #3
strat61caster
strat61caster's Avatar
Put the right bolt in the right hole, torque to spec, check periodically. Imho once per year for a casual DD car makes sense.
ineedyourdiddly
Old 04-07-2018, 04:21 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
JB Weld
Old 04-08-2018, 03:41 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Regarding safety precautions to prevent slip:
1) don't use camberbolt if aftermarket strut is hole is slotted
2) it's easier if you mark with line of white paint after tightening position, so you can easily see if it has moved
3) use loctite or alike (have heard miscelaneous varieties, like generic paint to nail polish) for bolts to enhance contact/friction/prevent movement). This were mentioned in relation for more secure mount on slotted struts to prevent possible movement, but probably will work also with camberbolts.
But in general usage of normal camberbolts is safe enough. Yes, they are a bit weaker then stock bolts of a bit larger diameter, but most often if you brake camberbolt, there has been that heavy hit to suspension that also may bend suspension parts, that would have been bent even with stock.
The Following User Says Thank You to churchx For This Useful Post:
TofuJoe (04-08-2018)
Old 04-08-2018, 03:43 AM   #6
mkodama
86 Challenge
Drives: 2017 BRZ
I have the SPC lower bolts and the camber maxes out around -1.5 degrees. I’ve done 4 track days and daily driving on them, no issues noticed.
The bolts seem overkill strong and your biggest worry are alignment shops that don’t properly torque them.
mkodama is offline   Reply With Quote
The Following User Says Thank You to mkodama For This Useful Post:
gpvecchi (04-08-2018)
Old 04-08-2018, 04:14 AM   #7
gpvecchi
gpvecchi's Avatar
Many thanks to everyone! I just ordered Eibach ones.
Old 04-17-2018, 06:09 PM   #8
IndyBRZed
Drives: 2017 BRZ Limited Auto
Install correctly,
The shank that contacting the strut surfaces are same O.D. as your factory bolt. The Cam is contacting your spindle. If your spindle is in Negative camber its at angle that would favor hitting bumps since its forcing a Tilt ( / ) . Also if you do the 14mm stock in the 16mm hole tighten efficiently and a tip I have done in the past is spot weld it slightly. Not crazy so if you ever set it again you can knock it off with a hammer and chisel.
IndyBRZed is offline   Reply With Quote
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 09:06 PM
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) Joesurf79 Brakes, Suspension, Chassis 2 01-13-2017 05:03 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
