Old 03-26-2018, 10:39 PM   #1
HSUBLU
Drives: 2017 BRZ WR Blue
Lucked out on camber bolts!
Only one set of SPC camber bolts on stock suspension, installed on the top, and managed to get this out of it:
Looking forward to this AX season, that's for sure.
HSUBLU is offline   Reply With Quote
Old 03-26-2018, 10:43 PM   #2
strat61caster
strat61caster's Avatar
14mm or 16mm?
ineedyourdiddly
Old 03-26-2018, 10:48 PM   #3
HSUBLU
14mm or 16mm?
It was the SPC 81305.
Old 03-26-2018, 10:56 PM   #4
Lex_K
Drives: 987S, e46, mkv, frs
That’s it? We are getting 3.2-3.4 with camber bolts in SSC.
Lex_K is offline   Reply With Quote
Old 03-26-2018, 11:01 PM   #5
HSUBLU
I'm sitting on stock suspension for now. Coils aren't really going to be in the works until at least next year, and I'm looking at STX instead of SSC. I really like that I don't have the torque dip any more with the headers I've got on there and I don't really fancy putting the stock headers back on to qualify for SSC.
Old 03-26-2018, 11:35 PM   #6
strat61caster
Yeah that's the 14mm cam bolt, it should go in the bottom hole, not the top. Hopefully the shop put it in the bottom hole and swapped the OE lower bolt to the top bolt, otherwise you have a seriously undersized bolt in the top hole. It'll probably be fine but there's a small chance that have a bolt that small may be stressed improperly and may fail, especially if it comes loose.
SPC website showing that P/N is the smaller 14mm bolt:
http://www.spcalignment.com/componen...tion&pid=81305
81280 is the 16mm bolt for the top hole
http://www.spcalignment.com/componen...tion&pid=81280
Apparently you used a different part number than I did, my 14mm bolt was 81260
The Koni struts for SSC have an oversized hole, the OE struts have one hole that's smaller than the other limiting camber. Minor CS scandal when it was figured out, Koni sent out washers to bring the struts back into spec but apparently left the enlarged hole for the SSC build.
http://apexjunky.com/2015/12/koni-ad...al-for-frsbrz/
fwiw it's pretty common for a single camber bolt in one hole (oe or aftermarket) and the proper factory bolt in the other hole limits camber to being no more than 2 degrees. I'd suspect OP's shop installed it the 'proper way' similar to SSC, 14mm cam bolt lower hole, OE small bolt upper hole and the OE struts are limiting it to -2.4. A good tech might be able to find another tenth or two with some effort, but the enlarged hole in the Koni's was worth about half a degree to one degree iirc.
ineedyourdiddly
Old 03-26-2018, 11:44 PM   #7
HSUBLU
SPC website showing that P/N is the smaller bolt:
Oh boy, wish I would have been able to find information on this before I bought and installed the bolts...
Old 03-26-2018, 11:48 PM   #8
strat61caster
As far as I'm concerned you bought the right one: maximum camber/$
Edit: This thread has a brief summary of camber bolt options that's pretty straightforward
http://www.ft86club.com/forums/showthread.php?t=103609
ineedyourdiddly
HSUBLU (03-27-2018)
Old 03-26-2018, 11:49 PM   #9
FirstWinter
Drives: Car
FirstWinter is offline   Reply With Quote
Old 03-27-2018, 12:01 AM   #10
HSUBLU
Originally Posted by FirstWinter View Post
Only six years worth of threads to sift through, the threads that I did find didn't mention this, so apparently my google fu is not up to snuff.
While I understand that the easiest response in forum history is "Have you used the search button?", realizing that searching through this needle stack and making sure you found the right needle isn't always the easiest damn thing.
Old 03-27-2018, 12:02 AM   #11
HSUBLU
I mean it when I said whatever search parameters I was using didn't get me to this thread. But this thread has stuff I wish I saw...
Old 03-27-2018, 12:15 AM   #12
strat61caster
Use Google to find threads, not the on site search, just add ft86club to the search and results from this site will be first.
ineedyourdiddly
HSUBLU (03-27-2018)
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 10:06 PM
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) Joesurf79 Brakes, Suspension, Chassis 2 01-13-2017 06:03 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
