Old 03-20-2018, 03:27 AM   #1
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Coilpack issue P0353 after track session
Not sure if this is the right place for this but it is track related so here we go.
I got the CEL in one of my session P0353 so I have to skip my last session and call it a day. After arriving home still has the CEL, left the car off and parked. When I needed to transfer the car, I noticed the CEL is gone. What is the best way to approach this? Will it comeback on my next track session? I saw some post that they bring extra updated coilpack or just change the coilpack that triggered the code with the updated one. What did you guys do? Searched also that the wiring harness was changed but never really had a TSB for iy. Thank you. Car is MY14 40k miles. All stock except for the axleback. Thank you.
tintumz22 is offline   Reply With Quote
Old 03-20-2018, 09:01 AM   #2
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I had the same thing happen to me last year at the track. The CEL went away bc the coilpacks fail when they are hot. The second they cool down to an acceptable temp they start working again. Sometimes. Others have not had such good luck and have misfires and other issues.
HERE is the thread that helped me with this issue. I recommend some cool tape or some hood venting and to carry an extra. See my build thread for cool tape and venting pics.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
tintumz22 (03-20-2018)
Old 03-20-2018, 10:29 AM   #3
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Once they throw a code, they will do it more and more easily. I had mine replaced along with the entire wiring harness under warranty and that seems to have fixed it (at least temporarily).
When I finally gave up and took it into the dealer, I could get the code to trip by just revving past 6k rpm (no high temps required).
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
Old 03-20-2018, 12:58 PM   #4
tintumz22
tintumz22's Avatar
How did the gold cool tape go so far? did you have to change your coilpacks?
Old 03-20-2018, 12:59 PM   #5
tintumz22
tintumz22's Avatar
how is your car running now? any update? is it still having the issues?
Old 03-20-2018, 01:08 PM   #6
14stu
14stu's Avatar
I've done another 6-8 trackdays and about a dozen autocrosses without any issues. I've spent literally hours above 6k rpms since then and haven't had the issue return.
I had done fewer events before I originally got the CEL, so I think the problem is fixed.
Old 03-20-2018, 01:34 PM   #7
tintumz22
tintumz22's Avatar
Wow. That is so nice that it have not come back. I have an event coming up next month but just not sure coz if I get the CEL and that might just waste my day at the track.
So the fix was the harness and the coilpacks being replaced? what did you do to get the dealer fix them? I searched about the harness thing but i dont really see an actual TSB for it. the CEL is gone and ive been trying to do a pull at WOT in all gears but no CEL yet.
Old 03-20-2018, 01:47 PM   #8
Takumi788
JHerbert Racing
Takumi788's Avatar
Unfortunately I do not have results to share. I did this over the winter and here in NY the weather is still terrible. My first track event with these modifications is April 24th. I have heard that the tape method works tho.
I moved the coil packs that were above the over pipe to the driver side and vise versa. I also have a brand new spare just in case.
Old 03-20-2018, 01:47 PM   #9
Takumi788
JHerbert Racing
Takumi788's Avatar
Do you happen to have the new harness part number? I would like to do this as well.
Old 03-20-2018, 01:54 PM   #10
Ragin Gti
Drives: '15 Subaru BRZ
Subaru TSB 07-120-17R. Not sure on the Toyota TSB #. Yes the bulletin involves replacing the engine wiring harness and all 4 coils. The updated parts were used starting with 2015 MY production.
Ragin Gti is offline   Reply With Quote
The Following User Says Thank You to Ragin Gti For This Useful Post:
Old 03-20-2018, 02:03 PM   #11
tintumz22
tintumz22's Avatar
Originally Posted by Ragin Gti View Post
Subaru TSB 07-120-17R. Not sure on the Toyota TSB #. Yes the bulletin involves replacing the engine wiring harness and all 4 coils. The updated parts were used in production starting with 2015 MY production.
trying to find it google but no pdf file for it so I can just print it and bring it to them just like i normally do.
Old 03-20-2018, 02:05 PM   #12
tintumz22
tintumz22's Avatar
Okay. Currently the CEL disappeared itself w/o me clearing it but most likely it is stored right? Can I bring it to the dealer and tell them that that code came up?
Old 03-20-2018, 02:30 PM   #13
Takumi788
JHerbert Racing
Takumi788's Avatar
Got it. Thanks! Harness # 24020AG080 Coil part # 22433AA730 - embarrassingly enough it was in that thread that I linked in my first post.
Old 03-20-2018, 03:12 PM   #14
14stu
14stu's Avatar
The CEL should be in the memory, you could probably get it to come back by revving up near redline (I had mine clear and stay off for months of daily driving only to come back on track early). You can continue tracking with the CEL, performance is marginally decreased but only near redline and not enough to ruin your day.
My dealer changed everything without any fuss, but they've been great to me with warranty work (I pulled in for them to document the code after driving straight from the track with my helmet in the passenger seat and stickers still on the car).
The new coilpacks for MY15+ are a different shape from the 13-14 ones, so you couldn't just swap to the new coils.
The Following 2 Users Say Thank You to 14stu For This Useful Post:
Takumi788 (03-20-2018), tintumz22 (03-20-2018)
OFT OTS TUNE= Coilpack killer?? tCsonfrs Issues | Warranty | Recalls / TSB 42 11-08-2018 09:11 AM
CEL and Slip Light DTC P0353 rocketbunny86 Issues | Warranty | Recalls / TSB 7 03-23-2016 08:38 PM
Stalling after full track session IShouldStudy Issues | Warranty | Recalls / TSB 22 12-13-2013 02:34 PM
Driver window issue? Off track? s14sleepyeyez Issues | Warranty | Recalls / TSB 7 06-07-2013 09:19 PM
FT-86 Competition / Track model mentioned in EVO Car Of The Year Issue Axel Scion FR-S / Toyota 86 GT86 General Forum 132 03-07-2010 11:33 PM
