Drives: 2013 Scion FR-S Toyota 86
Coilpack issue P0353 after track session
Not sure if this is the right place for this but it is track related so here we go.
I got the CEL in one of my session P0353 so I have to skip my last session and call it a day. After arriving home still has the CEL, left the car off and parked. When I needed to transfer the car, I noticed the CEL is gone. What is the best way to approach this? Will it comeback on my next track session? I saw some post that they bring extra updated coilpack or just change the coilpack that triggered the code with the updated one. What did you guys do? Searched also that the wiring harness was changed but never really had a TSB for iy. Thank you. Car is MY14 40k miles. All stock except for the axleback. Thank you. |
#2 |
JHerbert Racing
Drives: 2013 Scion FRS
I had the same thing happen to me last year at the track. The CEL went away bc the coilpacks fail when they are hot. The second they cool down to an acceptable temp they start working again. Sometimes. Others have not had such good luck and have misfires and other issues.
HERE is the thread that helped me with this issue. I recommend some cool tape or some hood venting and to carry an extra. See my build thread for cool tape and venting pics.
| The Following User Says Thank You to Takumi788 For This Useful Post: | tintumz22 (03-20-2018) |
#3 |
Drives: 2014 Subaru BRZ
Once they throw a code, they will do it more and more easily. I had mine replaced along with the entire wiring harness under warranty and that seems to have fixed it (at least temporarily).
When I finally gave up and took it into the dealer, I could get the code to trip by just revving past 6k rpm (no high temps required). |
| The Following User Says Thank You to 14stu For This Useful Post: | tintumz22 (03-20-2018) |
#4 | |
#5 | |
#6 | |
I had done fewer events before I originally got the CEL, so I think the problem is fixed. |
#7 | |
So the fix was the harness and the coilpacks being replaced? what did you do to get the dealer fix them? I searched about the harness thing but i dont really see an actual TSB for it. the CEL is gone and ive been trying to do a pull at WOT in all gears but no CEL yet. |
#8 | |
JHerbert Racing
I moved the coil packs that were above the over pipe to the driver side and vise versa. I also have a brand new spare just in case.
#9 |
JHerbert Racing
Do you happen to have the new harness part number? I would like to do this as well.
#10 |
Drives: '15 Subaru BRZ
Subaru TSB 07-120-17R. Not sure on the Toyota TSB #. Yes the bulletin involves replacing the engine wiring harness and all 4 coils. The updated parts were used starting with 2015 MY production.
Sent from my iPhone using Tapatalk Last edited by Ragin Gti; 03-21-2018 at 12:25 PM. |
| The Following User Says Thank You to Ragin Gti For This Useful Post: | tintumz22 (03-20-2018) |
#11 |
trying to find it google but no pdf file for it so I can just print it and bring it to them just like i normally do.
#12 | |
#13 |
JHerbert Racing
Got it. Thanks! Harness # 24020AG080 Coil part # 22433AA730 - embarrassingly enough it was in that thread that I linked in my first post.
#14 | |
My dealer changed everything without any fuss, but they've been great to me with warranty work (I pulled in for them to document the code after driving straight from the track with my helmet in the passenger seat and stickers still on the car). The new coilpacks for MY15+ are a different shape from the 13-14 ones, so you couldn't just swap to the new coils. |
| OFT OTS TUNE= Coilpack killer?? | tCsonfrs | Issues | Warranty | Recalls / TSB | 42 | 11-08-2018 08:11 AM |
| CEL and Slip Light DTC P0353 | rocketbunny86 | Issues | Warranty | Recalls / TSB | 7 | 03-23-2016 07:38 PM |
| Stalling after full track session | IShouldStudy | Issues | Warranty | Recalls / TSB | 22 | 12-13-2013 01:34 PM |
| Driver window issue? Off track? | s14sleepyeyez | Issues | Warranty | Recalls / TSB | 7 | 06-07-2013 08:19 PM |
| FT-86 Competition / Track model mentioned in EVO Car Of The Year Issue | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 132 | 03-07-2010 10:33 PM |
