Old 01-13-2015, 11:02 PM   #1
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Pulsing when Accelerating
When fully stopped, if I quickly apply gas at about 3/4 of WOT or more, the engine "pulses" and won't stop until I let go of the throttle and slowly reapply. it's fairly embarrasing at an intersecrion, seeing my car move slightly back and forth on its suspension while slowly moving foreward (~5 mph).
I have tried looking up solutions to this issue, and some belive that the ECU may be faulty, the fuel injection may be faulty, certain wires are "dirty", or that unbalanced tires are at fault.
There is a very low probability that the tires are the issue because this also occured before I stepped up to stickier SummerTires.
I have had this issue since I bought the car, but originally thought it was just me being very bad at driving a manual, and then later believing it was the 87 octane gas I was using.
Any insight is appreciated.
Edit: I drive a manual
carma143 is offline   Reply With Quote
Old 01-13-2015, 11:06 PM   #2
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Auto?
blue cat is offline   Reply With Quote
Old 01-13-2015, 11:13 PM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Does the TC light come on on the dash?
Are you still using 87? (also why 87?!?)
What RPMs? (Wouldn't happen to be ~3000-4200 right?)
Does it continue through redline?
Decay107 is offline   Reply With Quote
Old 01-13-2015, 11:37 PM   #4
Fastbrew
Drives: 2014 Pearl White BRZ
Has someone changed the clutch?
Fastbrew is offline   Reply With Quote
Old 01-13-2015, 11:38 PM   #5
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
My first guess would be the traction control, especially if your car has an automatic transmission.
Old 01-13-2015, 11:49 PM   #6
otterpop
Drives: 2015 scion frs
I also happen to get this randomly though from a stop to a go. it usually happens right off the bat around 2K rpm + and doesn't stop until I shift. It doesn't happen all the time, only happens rarely. I have never seen any lights come on and I have never really noticed it hurting the car in anyway. Maybe i'm just bad at a manual.
otterpop is offline   Reply With Quote
Old 01-14-2015, 12:06 AM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
If 3/4 or WOT makes your car move slowly through an intersection...I think you got bigger problems.
N1rve
Old 01-14-2015, 12:51 AM   #8
carma143
carma143's Avatar
The TC light does not turn on. This occurs even when I have pressed the center button for ~5 seconds "mostly" turning off TC and Stability.
I stopped using 87 octane several months ago. I used about 2.5 tanks of it before I switched (1 is assumed from dealer when bought).
The clutched has not been changed while in my posession.
I'll have to check tomorrow what rpms the car stays at when this happens. this issue is very easily repeatable (not happening "randomly").
Edit: Could it be a faulty spark plug?
Taken from a BMW Forum:
"Anyway, what they ended up doing was replace an ignition coil because the retainer was not holding the coil on the plug. Whatever code was being thrown was indicating a misfire on cylinder 3, as even someone as non-mechanical as myself thought."
Old 01-14-2015, 01:00 AM   #9
carma143
carma143's Avatar
When this occurs, there is no meaningful acceleration, a.k.a. stays at around 5 mph no matter how far down I press down the pedal. Feathering the gas (allowing the car to move slowly), then WOT typically does not result in this bog.
Old 01-14-2015, 01:36 AM   #10
Decay107
Decay107's Avatar
If you don't have a code, the engine probably isn't misfiring. Any chance for a video?
Old 01-14-2015, 01:59 AM   #11
CokeSlap
Drives: 2014 Monogram FRS Whiteout
My money is on the traction control. It has been a real pain during the cold days in Nebraska with just a light dusting on the ground.
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl
CokeSlap is offline   Reply With Quote
Old 01-14-2015, 02:24 AM   #12
carma143
carma143's Avatar
I have a friend with a GoPro. I'll see if I can borrow it for half an hour or so.
Just so we are clear, the BMW from the forum was sending out a code indicating a misfire even though there was none, shutting off a functioning valve "valve 3" for a fraction of a second, continuously, causing a large jerk with the coninuous loss and gain of the valve's power. The jerking I get is pretty violent, but I don't hear any out of the ordinary sounds occuring.
Old 01-14-2015, 08:18 AM   #13
kodyo
Drives: Scion FR-S
I think I know what you are referring to and I'm pretty sure it's the syncros in the transmission getting everything up to speed. When it begins to surge on mine, I can accelerate out of it though. Experiment with letting out the clutch and modulating the gas differently. Have you changed trams fluid yet?
kodyo is offline   Reply With Quote
Old 01-14-2015, 09:48 AM   #14
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Wheel hop?
celica73 is offline   Reply With Quote
ecu, gas, pulsing, throttle
Ticking/Clicking noise when accelerating? Pineapple Issues | Warranty | Recalls / TSB 3 08-28-2014 03:29 PM
question regarding screeching sound when accelerating kudougw Scion FR-S / Toyota 86 GT86 General Forum 12 07-18-2014 03:37 PM
weird pulsing while stopped neil125 Issues | Warranty | Recalls / TSB 2 05-14-2013 11:04 PM
accelerating from a dead stop jarviz Scion FR-S / Toyota 86 GT86 General Forum 78 07-26-2012 02:11 PM
A/C Shifts off when accelerating hard? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 29 06-19-2012 12:24 AM
