Old 03-13-2018, 06:06 PM   #1
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Erratic Oil Pressure Over 6k RPM
So I noticed on my last track day my oil pressure would climb to almost 80, then after 6k would fall off and go all erratic bouncing between high 40's-mid 60's. It kind of freaked me out, so I started short shifting and backed it down. Anyone else with a gauge notice similar behavior? My oil was on the low end of the dipstick but I can't imagine that is enough to cause that. Oil temps never went beyond 220-230 range. Ambient temp was about 60, highest coolant temp I saw was 208. Pulling oil pressure from the factory sensor location on the front of the left side of the timing cover. Was using RP 5W-30. Going to 300V on my next oil change.
Old 03-13-2018, 07:27 PM   #2
humfrz
If you were on steep curves, maybe the oil pump couldn't find as much oil to grab hold of .....??
humfrz
Old 03-13-2018, 07:37 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
humfrz
It was doing it on the front straight when I see it most. I am thinking that the oil filter was bypassing at those RPM's causing the drop but I dunno. All of the longer turns were lefts and my forearm blocks my gauge on a left.
Old 03-13-2018, 07:46 PM   #4
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
There have been reports of the oil pump cavatating above 7000 rpm.
What weight oil are you using? Most people on track go to 30 over 20 weight oil.
Also I would keep the oil level topped off.
Lunatic is offline   Reply With Quote
Old 03-13-2018, 07:49 PM   #5
humfrz
Maybe the oil pressure gauge itself is just messing with you .....??
Maybe that's why most cars don't have oil pressure gauges to alarm people ..... just lights that come on, after the engine has blown up ......
humfrz
Old 03-13-2018, 07:52 PM   #6
humfrz
I believe he said that he was using 5W-30.
humfrz
Old 03-13-2018, 08:03 PM   #7
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
top it off every time before you go on the track, our oiling system sucks for high rpms.
Old 03-14-2018, 03:54 PM   #8
wheelhaus
wheelhaus's Avatar
If the sensor sends a voltage back as a signal then could it be possible the connection is flaky at certain voltages/resistances/vibration frequencies/position of the moon/etc?
If not, i agree keep the oil topped off at the full mark. Our little engines don’t hold much oil, so being nearly a quart low is a big quantity of the available volume.
wheelhaus is offline   Reply With Quote
Old 03-14-2018, 09:09 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I will keep on eye on it and report back. I did do a 2nd gear pull on the street and noticed similar behavior but not as exaggerated. It just seemed to plateau and not really drop though not possible to replicate track temps on the street. Oil was topped off.
Old 05-26-2019, 09:41 PM   #10
Passion86
Drives: 2013 Subaru BRZ
Aright, I know I'm reviving an old thread, but I thought I better start here before creating a new one about the same issue. I installed an oil pressure gauge on a previous motor that blew, and put it on the new motor installed by warranty. I've recently started doing a lot more hwy cruising and noticed at 85mph or around 4600-4800 rpms my oil pressure would start to jump around erratically between 30-55 psi. If I backed off my speed to 83mph it was stable, and if I bumped it up to 90mph it again stabled out. I recently had my motor serviced for the valve spring recall, and asked him if he would check it out. He said he took the gear out of the front cover, cleaned everything up, and everything looked fine. Still jumps erratically at those speeds, so we determined it must be some kind of harmonic resonance and it starts to fluctuate like that. I still don't cruise at that speed though, as that's the speed I was going on the hwy when I blew the first motor. Which has had me thinking quite a bit about it.
Passion86 is offline   Reply With Quote
The Following User Says Thank You to Passion86 For This Useful Post:
jcw99 (05-27-2019)
AFR mostly rich, erratic at times Synack Forced Induction 49 07-07-2018 11:15 AM
OFT is flashing on and off sporadically...very erratic! chazmuska Software Tuning 3 01-16-2018 12:59 AM
Scion FRS Police Standoff Erratic Driver Arrested After Chase Speed2th Off-Topic Lounge [WARNING: NO POLITICS] 7 05-22-2016 03:38 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
