Old 03-08-2018, 10:43 PM   #1
wbradley
Sarcastic SOB
wbradley's Avatar
Where to buy a partial oil cooler kit?
Strange request for advice here.
I had installed a CX Racing oil cooler a few years ago and the fittings and sandwich plate left somewhat to be desired. The heat exchanger included brackets allowing the mount directly behind my intercooler. This was a need in my case since my intercooler fills the entire opening in the grille.No I didn't choose this product for cheapness. My alternative would have been an HKS system which is really nice except it requires cutting a big hole in the passenger side wheel well liner.
Anyway the lines leaked where the AN fittings pivoted after a short while so I disconnected it.
Now I want to order new braided 4' lines with AN -8 male fittings both ends and a quality sandwich plate.
Where's a good place to order a partial oil cooler?
Cheers
Old 03-08-2018, 11:10 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
RacerX Fabrication sells just their sandwich plate. For the line and fittings you will have to go trough a Jegs or Summit, or find a company locally that can make them for you.
Old 03-09-2018, 12:41 AM   #3
CoolHandMoss
Drives: 2013 FRS
Just get 10' of hose and the fittings you need and put it together. It is recommended to get the fittings of the same brand as the hose that you get. As stated above, jegs or summit are good sources. I just put together an oil cooler using summit brand lines and fittings and after a few weeks of use I'd say I recommend the summit brand -AN stuff. Of course there are other good options.
As for the plate, the Mocal plate seems to be well liked. That's what I used and I'm not really impressed. If I were to do it again I'd try the racerx plate to see if the flow path looks any better on it.
CoolHandMoss is offline   Reply With Quote
Old 03-09-2018, 01:19 AM   #4
FirstWinter
Drives: Car
Summit Racing or similar vendors that sell parts individually. There's a bunch of them. Some of them are mentioned by the other posters.
FirstWinter is offline   Reply With Quote
Old 03-09-2018, 01:34 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Mocal thermostatic plate's nice.
Old 03-09-2018, 07:37 AM   #6
wbradley
Sarcastic SOB
wbradley's Avatar
Mocal plate and 10' of hose with all fittings is $384+ at Racer Parts Wholesale. That's about $1,000,000 Canadian landed. LOL
This requires the lines and fittings to be assembled still and I prefer not to buy specialized tools for a one time use. I will check the others.
Old 03-09-2018, 12:34 PM   #7
Ultramaroon
not playing cards
I guess it depends on the fittings. I'm not advocating one way or another, but I went with the slightly bulkier, reusable style. No special tools. Using the same Startlite hose as well.
Bummer about the cost, though. :|
Old 03-09-2018, 12:53 PM   #8
fika84
fika84's Avatar
Amazon sells some AN line with fittings kits for pretty cheap...
fika84 is offline   Reply With Quote
Old 03-09-2018, 01:50 PM   #9
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
www.pegasusautoracing.com
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 03-09-2018, 03:13 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
https://www.racerpartswholesale.com
Old 03-09-2018, 03:47 PM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
That was including reusable fittings. I thought you need a special tool to press the fittings onto the hose.
Old 03-09-2018, 04:25 PM   #12
CoolHandMoss
Drives: 2013 FRS
You don't really "need" a special tool to assemble basic -AN fittings. As for the cost, most of the expense isnin the thermostatic plate. I believe the Mocal runs about $180. The racerx plate is $120 and if you want cheap you could go with the derale option. I actually have an unused derale plate I'd sell you below retail. I was going to use it but once I saw it I decided to invest in the Mocal. The $384 price including lines is really high. Like everyone is saying, get some -AN fittings and line from summit or jeggs or some other racing supply vendor.
Old 03-09-2018, 04:37 PM   #13
fika84
fika84's Avatar
10' of 6AN with an assortment of fittings for $50
https://www.amazon.com/Evilenergy-Ny...an+fitting+kit
Old 03-09-2018, 05:34 PM   #14
Ultramaroon
not playing cards
Not at all. Just need a light smidge of grease in the tube and the thread. Tighten down until only a couple threads show between the collar and insert. There will be a gap.
Aluminum wrenches are available if you care about the finish. IDGAF
Guys, he's Canadian. No matter where he shops, he gets raped with the import duty.
Sold. I think. Partial payment accepted. Mr. Exterior Parts (Aero, Lighting, Etc.) 5 12-29-2015 04:17 PM
Hesitation Under Partial Throttle! Jhood Forced Induction 27 12-06-2015 12:20 PM
Partial Throttle Issue sw20kosh Software Tuning 4 07-18-2014 03:33 PM
Partial Stall's WRB Partial Stall Member's Car Journals 3 06-07-2012 06:53 PM
Partial Accessory Pricing MrBRZ Scion FR-S / Toyota 86 GT86 General Forum 1 04-25-2012 12:02 AM
