Old 07-17-2014, 10:43 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Partial Throttle Issue
Just wondering if anyone else has an idea of what is going on here:
Setup:
ptuning turbo kit
stock injectors
ptuning specific MAF scaling
ECUTEK tune
Everything runs great. Car makes good power 280 on 91 octane. Maintains great WOT AFR 11.8 ish.
Until you do partial throttle at the 4k rpm zone. If you hold a constant 30% throttle position starting at 3500 rpms, it feels like the engine loses some 'umph' (dead zone) as you climb the rpm range and then all of a sudden, somewhere north of 4k rpm the power will come back and you surge forward.
In the logs, this is the only thing that correlates (MAF voltage is nice and smooth):
This is a plot of Wideband AFR.
Thanks for any input.
Old 07-18-2014, 03:22 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Well that looks like it's going lean. The power returns as the AFR returns to a decent level. Any chance you have the corresponding view for fuel system status? If it's already in open loop then you will need to sort out the MAF to bring the AFRs down in that region, or just make the AFRs richer in the fuel table for the RPM/Load region.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-18-2014, 12:16 PM   #3
sw20kosh
Here are two new logs. Purple is AFR. Blue is Fuel Sys Status.
Old 07-18-2014, 01:32 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Well it looks fine as soon as it goes into OL. It looks like the CL needs to richen off slightly (if that's possible, I haven't really played with CL fueling) or maybe try getting it to transition into OL a little sooner.
The dead spot is definitely because it's getting leaner and then when the fueling reaches a good ratio again, that is where you feel the lurching forward.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
sw20kosh (07-18-2014)
Old 07-18-2014, 03:33 PM   #5
sw20kosh
Yep tuner is looking into the CL issue. Hopefully it is figured out! Thanks for your analysis! I really appreciate it.
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Electronic Throttle Issue FRiSson Issues | Warranty | Recalls / TSB 0 09-28-2012 10:35 AM
Partial Stall's WRB Partial Stall Member's Car Journals 3 06-07-2012 06:53 PM
Partial Accessory Pricing MrBRZ Scion FR-S / Toyota 86 GT86 General Forum 1 04-25-2012 12:02 AM
