Old 03-07-2018, 12:33 AM   #1
86King
Drives: FR-S Monogram
HELP!!! Turn signals dont work
After a year, my turn signals started to fail again.
When it is light outside and headlights are off (DRLs on) I go to turn on my right turn signal, it flashes on the dash and makes the ticking noise and at the same time my climate and infotainment screen flash at the same pace.
When it is dark outside and headlights are on, the turn signals on the dash iluminte and get brighter as the car is warming up. Neither of the signals work outside the car. The right turn signal is only illumitaed outside the car, and stays iluminated. Hazards also do not work.
This happend about a year ago, but not this bad where lights outside the car would not work. It eventually went away, until the past week.
I have a 2014 FR-S Monogram edition, with aftermarket turn signals all around. (Switch backs in the front, LEDs in the back and aftermarket side markers)
Any help would be appreciated!!
86King is offline   Reply With Quote
Old 03-07-2018, 01:13 AM   #2
humfrz
Well, now that's a pain .....
Always check the fuses first....
Did you install the after market lights ..??
If so, you may wish to recheck your work.
If not, you may wish to take the car back to who did the installation (if possible).
I'm guessing you have a short or bad ground somewhere.....
humfrz
Old 03-07-2018, 01:07 PM   #3
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Happened on my FR-S with aftermarket switchbacks, the solder joints in the switchbacks came loose and was crossing connections which caused some strange electrical issues.
If you have access to FB, you can see it in this video.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 03-07-2018, 01:14 PM   #4
StraightOuttaCanadaEh
Wes
Your car is trying to become a BMW!
Instagram: @gt86ws
Old 03-07-2018, 09:02 PM   #5
gravitylover
Or a Chrysler product
Old 03-07-2018, 09:05 PM   #6
n0thing
Drives: Subaru BRZ
n0thing is offline   Reply With Quote
How to take apart frs Turn Signals? Hentai Cosmetic Modification (Interior/Exterior/Lighting) 6 10-12-2016 12:49 PM
Turn signals don't always automatically turn off one2onejackpot Issues | Warranty | Recalls / TSB 6 04-18-2016 07:35 AM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Help! Headlights/turn signals don't work and I can't get my car out of park Cajun Cosmetic Modification (Interior/Exterior/Lighting) 27 01-11-2013 11:02 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
