Drives: Whiteout / MT FR-S
5.8 quarts too much?
So i changed out my break in oil and i put 5.8 quarts in yesterday as per recommended by the manual. Now i go to check my oil levels tonight after it had been sitting and it looks like the oil is going well beyond the fill line. We made sure to put 5.8 in, so im very perplexed. Is this going to hurt the cats and engine?
Drives: Nevermorange FRS
Make sure the car is level when you check it. Also, run it for a minute to fill up the filter and get oil throughout the engine. Turn off, then check.
If you over filled, then let some out. Next time when filling, put in 5 quarts then run and check and then add the other .8 if necessary. |
I Love custom Turbo kits
Drives: Limited BRZ
I believe everyone who has posted about the oil change has said 5.8 is too much. I wonder what is the sweet spot. I think I read somewhere else it was about 5.4
That guy
Drives: Ultramarine mt FR-S
I did 5.5 with "stock" filter. I put 5 in, dvds then added and tested levels 2 more times until prefect.
Registered you sir
Drives: 99 impreza coupe
To put 5.8 in is to assume you drained 5.8 out... so, since you didnt remove 100% of the oil ( not practically possible) you should not have refilled 100% of the capacity.
Fumoto valve... I think I say it in every oil thread. |
I left the stock filter and put in about 5.2 quarts.
First86 & burning gas!!
Drives: Asphalt 2013 Scion FR-S
I have one of the FR-S launch meetings brochure that was given to dealer employees to get familiar with the car. It states oil capacity is 5.5 quarts.
Registered you sir
#9 | |
Old Schooler
Drives: GD, GC, NPS50
#10 |
#11 |
Drives: Whiteout Scion FR-S
#12 |
Drives: Mint-Tiffany blue FRS
has anyone used the cusco filters yet?
#13 |
Site Moderator
Drives: Stuff
Stock ones are good Toyo Roki filters, so no, don't see the point.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#14 |
Drives: 2013 FRS Whiteout
I think using any or most aftermarket oil filters is useless. I don't think theres enough advantage to cover the amount paid for them. There's an oil analysis around here after 4500 miles showing exceptional performance from the oem piece. My car used 5.5qts after the 150ml change, I think most cars will vary slightly due to amount drained, burnt and so forth.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
