Old 07-23-2012, 10:48 PM   #1
Brimford
Drives: Whiteout / MT FR-S
5.8 quarts too much?
So i changed out my break in oil and i put 5.8 quarts in yesterday as per recommended by the manual. Now i go to check my oil levels tonight after it had been sitting and it looks like the oil is going well beyond the fill line. We made sure to put 5.8 in, so im very perplexed. Is this going to hurt the cats and engine?
Brimford is offline   Reply With Quote
Old 07-23-2012, 10:57 PM   #2
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Make sure the car is level when you check it. Also, run it for a minute to fill up the filter and get oil throughout the engine. Turn off, then check.
If you over filled, then let some out. Next time when filling, put in 5 quarts then run and check and then add the other .8 if necessary.
Old 07-24-2012, 01:24 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I believe everyone who has posted about the oil change has said 5.8 is too much. I wonder what is the sweet spot. I think I read somewhere else it was about 5.4
Old 07-24-2012, 03:32 AM   #4
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I did 5.5 with "stock" filter. I put 5 in, dvds then added and tested levels 2 more times until prefect.
Hawaiian is offline   Reply With Quote
Old 07-24-2012, 06:44 AM   #5
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
To put 5.8 in is to assume you drained 5.8 out... so, since you didnt remove 100% of the oil ( not practically possible) you should not have refilled 100% of the capacity.
Fumoto valve... I think I say it in every oil thread.
chulooz is offline   Reply With Quote
Old 07-24-2012, 09:37 AM   #6
UncleFester
I left the stock filter and put in about 5.2 quarts.
UncleFester is offline   Reply With Quote
Old 07-25-2012, 09:45 AM   #7
terrypm
First86 & burning gas!!
terrypm's Avatar
Drives: Asphalt 2013 Scion FR-S
I have one of the FR-S launch meetings brochure that was given to dealer employees to get familiar with the car. It states oil capacity is 5.5 quarts.
terrypm is offline   Reply With Quote
Old 07-26-2012, 01:49 PM   #8
chulooz
Registered you sir
chulooz's Avatar
Why would you leave the used filter on there? That negates the benefits of clean oil, it all runs through a dirty filter.
Old 07-26-2012, 07:02 PM   #9
Acc
Old Schooler
Drives: GD, GC, NPS50
Should be fine...we put about that much in our FRS.
Acc is offline   Reply With Quote
Old 07-29-2012, 10:35 AM   #10
UncleFester
My K&N filter came a day late. I already had it drained cause I switched out the ATF as well. Gotta do whatcha gotta do sometimes.
Old 08-03-2012, 07:29 PM   #11
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
See the thread I started here:
http://www.ft86club.com/forums/showthread.php?t=11734
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 08-03-2012, 07:58 PM   #12
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
has anyone used the cusco filters yet?
kendalldwhite is offline   Reply With Quote
Old 08-03-2012, 08:16 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Stock ones are good Toyo Roki filters, so no, don't see the point.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-08-2012, 09:59 AM   #14
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I think using any or most aftermarket oil filters is useless. I don't think theres enough advantage to cover the amount paid for them. There's an oil analysis around here after 4500 miles showing exceptional performance from the oem piece. My car used 5.5qts after the 150ml change, I think most cars will vary slightly due to amount drained, burnt and so forth.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
