Old 02-20-2018, 08:32 PM   #1
AnthonyArcaro
AnthonyArcaro's Avatar
Drives: 2014 White Subaru BRZ Limited
Looking for some help on fitment
Currently I am running Eibach (82105140) Performance Spring Pro-Kit, which lowered the car roughly 1-1.5" all around with the stock strut. Recently I purchased 18x8 +35 wheels and 245x45x18 tires. However now that I have the tires next to my car they look MASSIVE. I was doing some research and some people say to go with a 245x35x18 or a 235x35x18. What would any of you recommend for good clearance because I do not want to have to worry about rubbing or rolling my fenders? Anyone have experience with running this setup with the same or similar suspension geometry?
Thank you,
Anthony
Daily 2014 Satin White Pearl BRZ Limited
Instagram: @subyota
AnthonyArcaro is offline   Reply With Quote
Old 02-20-2018, 10:46 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
245/35 18 would probably be closer to stock circumference. I mean if you're not currently rubbing on 245/45 18, you're not going to rub on 245/35 18.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
AnthonyArcaro (02-21-2018)
Old 02-20-2018, 11:02 PM   #3
AnthonyArcaro
Well I haven't gotten the tires mounted on the wheels yet thats my main concern is wasting the time and money to mount tires only for them not to fit.
Instagram: @subyota
Old 02-20-2018, 11:39 PM   #4
tyler_win_photo
It shouldn't rub.
Old 02-20-2018, 11:54 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
my $0.02
i had 245/35/18 on my 18x8 front wheels to match the rear tires on my 18x9s. but after driving on them , they were too wide. i took them off and got 225/40 on the fronts. now the steering is better. lighter, more precise. im running MPSS tires. and have eibach prokit spring too.
id suggest getting 225/40 on the 18x8 wheels. they will fit great at +35 offset and the tires are much cheaper!
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
AnthonyArcaro (02-21-2018), ZDan (02-21-2018)
Old 02-21-2018, 07:36 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
How'd you end up with that tire size? 26.7", two inches bigger in diameter than stock 24.7"! 215/40-18 or 225/40-18 are the sizes you should be looking at for an 18x8 wheel. The 215/40-18 is stock diameter, 225/40-18 a little bigger at 25.1" but still should be a good fitment.
Also be sure to pick a good tire make/model for your wants/needs and usage envelope. And check actual measured performance data at tirerack.com to be sure you don't get a crappy-performing tire.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
AnthonyArcaro (02-21-2018), Leonardo (02-21-2018), Tcoat (02-21-2018)
Old 02-21-2018, 07:53 AM   #7
AnthonyArcaro
Thanks man, I'm probably going to exchange them for a tire a bit smaller in diameter. Also I went with Comp 2s I heard they are a great all season tire.
Instagram: @subyota
Old 02-21-2018, 07:58 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
Comp 2 A/S looks good and comes in 225/40-18, that's your size
https://www.tirerack.com/tires/tests...y.jsp?ttid=222
The Following 4 Users Say Thank You to ZDan For This Useful Post:
AnthonyArcaro (02-21-2018), Leonardo (02-21-2018), Tcoat (02-21-2018), wparsons (02-21-2018)
Old 02-21-2018, 06:54 PM   #9
AnthonyArcaro
Yep exchanged and ordered them today, THANK YOU!!
Instagram: @subyota
Old 02-22-2018, 07:28 PM   #10
carlovestela
Drives: 2015 Firestorm FRS
What wheels did you buy?
Thank you,
Anthony
carlovestela is offline   Reply With Quote
TRD Kit fitment Ds3ire Cosmetic Modification (Interior/Exterior/Lighting) 20 03-16-2016 03:11 PM
Help on Fitment! lxsedan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-07-2015 10:01 AM
XXR fitment help raven1231 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-01-2015 01:05 PM
18x9.5 +45 fitment Wilson15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-05-2014 07:49 PM
Help with fitment BadLuckZN6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-24-2013 06:36 PM
