Old 02-17-2018, 05:44 PM   #1
JermMX5
Drives: 2017 Toyota 86
*FIXED* JDL UEL Header - Whooshing Noise
*FIXED* Check out post 16 for what the issue was
So got my JDL UEL header installed about a week ago, and I didn't really go under load until I got my EcuTek package from DT this week, and they had me do the 3rd gear full throttle pulls and the car sounds a lot different.
It almost sounds like an exhaust leak, but yesterday I literally went under there and retorqued ever bolt since it had been through a few heat cycles. It sounds like its coming from under the passenger side, is this just the sound tube? I was never annoyed by it before on the stock header, is it just worse once you go catless? Here's the clip! Thanks guys.
[ame="https://www.youtube.com/watch?v=rg-yiSPhaEM&app=desktop"]JDL UEL header noise under full load - YouTube[/ame]
Heres a full pull datalog incase anything in there points to a leak:
https://datazap.me/u/jermmx5/dt-ecut...r?log=0&data=6
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 02-17-2018, 05:50 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thinner manifold materials don't insulate sound as well It's commonly reported when people fit aftermarket manifolds.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-17-2018, 05:56 PM   #3
JermMX5
Awesome that's what I wanted to hear! Nothing in the log point to leak right?
Old 02-17-2018, 07:23 PM   #4
Teseo
Drives: frs
I have JDL UEL and doesnt sound like that, i dont have cabin sound tube so maybe could be that?
Old 02-17-2018, 07:59 PM   #5
JermMX5
See that's what I thought the sound might be, also are you tuned on EcuTek or OFT?
Old 02-17-2018, 08:00 PM   #6
StraightOuttaCanadaEh
Wes
That sounds awesome. Almost like it's boosted lol. Whoooossshhhh. Although I can see how it can be annoying. When I drive with the seats down, I can hear the fuel being sucked out of the tank and it's loud as hell. Starts to grate after a while, especially since I took all the trunk trim out
Instagram: @gt86ws
Old 02-17-2018, 08:05 PM   #7
Teseo
Drives: frs
OFT. i have axleback and maybe the exhaust sound mask that whoohy sound, i will report back when i drive the car next the time
Old 02-17-2018, 08:48 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I can confirm it disappears once you have an axleback as the car is indeed louder with the glorious exhaust sound. I have a nameless axleback as well as cnt catless uel tuned with OFT. Thinner wall headers make this sound quite a bit. In fact if you took off the heat shield and insulation material on the stock header I'm quite sure it would make a similiar sound.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Teseo (02-17-2018)
Old 02-17-2018, 10:32 PM   #9
strat61caster
strat61caster's Avatar
+1 normal welcome to aftermarket headers
exhaust leaks at the header or upstream of cats and resonators sound like nothing else
ineedyourdiddly
Old 02-18-2018, 06:02 AM   #10
Teseo
Drives: frs
Comfirmed. It sound like op described.
Old 02-18-2018, 11:39 AM   #11
JermMX5
Awesome thanks guys!
Last thing that I will be asking DT about once theyre back in the office is that I had a P015A engine code when I scanned with my bluetooth, but no check engine light, is that just random? Maybe it came up and then went away or is that the disabled code for the cat?
When I google it on the forums I find one other 2017 owner with it and everyone told him it was a bad O2
Old 02-19-2018, 09:35 AM   #12
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
That’s me! It didn’t end up being the O2 sensor. As soon as I went to better quality 91 oct, I haven’t seen the code appear again. Maybe it was coincidence, not sure.
Barefootdan is offline   Reply With Quote
Old 02-19-2018, 03:27 PM   #13
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Wouldn't matter either way.
Still can't wrap my head around how people would even think that makes a difference in this case.
Old 02-19-2018, 03:31 PM   #14
Teseo
Drives: frs
He asked, i replied
Raspy header and weird noise Scalzo Engine, Exhaust, Transmission 39 08-24-2020 07:40 PM
Uel catted jdl header noise dtrop Engine, Exhaust, Transmission 8 06-10-2016 01:18 PM
Engine noise after header install? JW843 Engine, Exhaust, Transmission 8 01-29-2016 12:29 AM
Borla Header Rattle Noise tonytduc Issues | Warranty | Recalls / TSB 40 05-09-2014 01:28 PM
Borla UEL Header noise? frslee Engine, Exhaust, Transmission 22 04-04-2014 11:37 PM
