Old 05-28-2016, 07:14 PM   #1
dtrop
Drives: Wrb 2014 limited brZ
Uel catted jdl header noise
Uel catted, thermal coated jdl header. First experience with after market header.
Installed by mechanic Wednesday, small sound coming from header.
Did stage 2 oft tune Friday, small sound stayed the same.
Sound was present in low rpm ranges, especially when stopping and accelerating from stop.
Today, sound got signicnantly louder and can even be heard during more rpm ranges.
Most noticeable in first 7 seconds of video.
dtrop is offline   Reply With Quote
Old 06-03-2016, 10:02 PM   #2
dtrop
[ame="https://www.youtube.com/watch?v=RMWxaFf5PdM"]Power loss 2500-3000 rpm - YouTube[/ame]
Getting a power loss between 2500-3000 rpm. Still haven't had a chance to get underneath the car yet.
Any recommendations?
Old 06-03-2016, 10:23 PM   #3
tinma
Drives: '13 BRZ
dont quote me, but I think you are supposed to run the OFT Stage 1 tune with catted UEL header
tinma is offline   Reply With Quote
Old 06-03-2016, 10:29 PM   #4
dtrop
I've read mixed opinions, and haven't reached a conclusion about that yet. Maybe i'll try flashing stage 1 tomorrow and see how it drives.
i'm okay with minimal power gains, just completely not okay with power or throttle losses.
Old 06-03-2016, 10:40 PM   #5
steve99
you will often notice different noises with aftermarket headers due to different construction and use of high flow metalic cats instead of ceramic cats, the metalic ones seem to let more high frequency noise through. you will ofen notice more ticking and whooshing type noises, just check you dont have an exhaust leak, if you can smell exhaust fumes under bonnet you will generally have a leak
Old 06-03-2016, 10:45 PM   #6
dtrop
is it recommended to use new gaskets? My car only has 19k miles on it. I just used the same gaskets.
Old 06-03-2016, 10:48 PM   #7
steve99
always use new gaskets they crush to form a seal, their single use only. If you resuse them they almost always leak after a couple of weeks.
Old 06-03-2016, 11:00 PM   #8
dtrop
alright, thanks again.
Gaskets ordered.
Old 06-10-2016, 01:18 PM   #9
dtrop
Finally got it up on the lift and here is the culprit.
Rubbing on the skid plate. Solution, banged out the skid plate a little and added a spacer near the area where contact was.
Now it sounds great.
The loss of power is still a mystery though. I also cleaned my MAF sensor and haven't had any issues since.
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
JDL Catted UEL header VS ft86speedfactory catted UEL Teclis Engine, Exhaust, Transmission 4 05-28-2015 02:19 PM
Catted header or catted front pipe? wilfredwong Engine, Exhaust, Transmission 5 02-09-2015 06:11 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
