Old 02-11-2018, 08:49 PM   #1
GrantedTaken
Dorman wheel stud? Just want to replace one.
One lug nut got stuck and I sheared the bolt in half with a breaker bar.
Got my wheels swapped, and I will carefully drive on 4 lugs for the time being.
When I have more time, I might replace all 20 with ARP.
For now, I just want to replace the one busted bolt.
Has anyone verified the gold $2 Dorman bolts an acceptable substitute?
http://www.rockauto.com/en/catalog/s...,lug+stud,7680
I just watched some videos as well.
To remove, I will try a ball joint separator or hammer it out.
When pulling on the new stud,
how do you know the splines are lined up?
Can you spin the bolt and feel it "click" into place?
Also, I've read a bunch on this topic, and it seems people dislike the OEM lug nuts?
Is there a popular lug nut replacement that is not bling, but just a functional upgrade.
GrantedTaken is offline   Reply With Quote
Old 02-11-2018, 10:00 PM   #2
Northern_18
Drives: Silver 2016 Scion FR-S
I have no experience with replacement studs for these cars so I don't know what will be best for you.
However, I've worked in a garage as a mechanic in the past and it is fairly easy to replace studs.
To remove the stud you can hammer it out. Once it is out, you will see that the splines don't actually line up with anything, they just grab into the metal and keep it from spinning when installing and removing the lug nuts due to the stud's splines being only slightly bigger than the hole the stud goes into.
To install the new stud your best bet would be to use another nut that has the same threads with a flat side on it so that you don't damage the angle on the lug nuts that is designed to match the rim by torquing it down against the flat surface of the hub.
Northern_18 is offline   Reply With Quote
Old 02-11-2018, 11:57 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What he said.
It's a press fit
On the brand side of thing, it's a lug stud. It's made of the same stuff oem is.
Old 02-12-2018, 12:55 AM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
A ball joint tool works perfectly for removal and install. I just did all my lugs. Youtube a video; it is easy.
I LIKE TIRES!
Old 02-12-2018, 01:51 AM   #5
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Good find! I've been replacing broken stock studs with these. They are much more durable. Only difference I've been paying $3 a piece for them at autozone.
Intent > Content
Old 02-12-2018, 07:49 AM   #6
GrantedTaken
That's weird about the splines not needing to be lined up.
If you look at a photo of the hub, you can see grooves in the holes, as well.
Old 02-12-2018, 10:17 AM   #7
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
It will align itself as it's pressed into the hub flange.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 02-12-2018, 11:21 AM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Dorman studs are OEM quality generally. In the case of these cars, I actually think they are a dash better.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 02-12-2018, 12:35 PM   #9
DarkSideFRS
Drives: 2013 pearl white FR-S
i just installed one yesterday... it was pretty easy...looks stronger than the OE ones... rent the ball joint puller from autozone
DarkSideFRS is offline   Reply With Quote
Old 02-12-2018, 03:09 PM   #10
GrantedTaken
Can you post a photo of the type of ball joint puller?
Does this one work?
https://i.ytimg.com/vi/ZcCfWmrVQfM/maxresdefault.jpg
Old 02-12-2018, 03:12 PM   #11
DarkSideFRS
Does the one in my first post work?
something like this.. they have it at autozone for rent.. u'll need a 24mm (i think) socket for tht bolt...and an impact gun makes it much easier
https://www.harborfreight.com/3-4-qu...tor-99849.html
Old 02-13-2018, 11:24 PM   #12
tyler_win_photo
tyler_win_photo's Avatar
Not sure what wheels you're running, but for lug nuts I would recommend something that is smaller than the stock 19mm lugs, like 17mm would be perfect, just so you have more clearance with your socket and to prevent accidental scratching when taking on and off wheels. As for material steel lug nuts have always been better to me than aluminum ones. Aluminum ones are too soft and can get easily stripped or cross-threaded.
tyler_win_photo is offline   Reply With Quote
Old 02-14-2018, 11:01 PM   #13
GrantedTaken
I got the $3 Dorman lug bolt installed.
Got a replacement Dorman lug nut for $2 also.
Used the washers, bolt, and electric impact to pull it.
The splines did feel like they lined up.
I got a bunch of M12 and M14 washers at HD for $2.
I also got an M12x1.25 bolt for .50 cents.
Better to use the open nut than a closed lug nut.
DarkSide, that HF tool worked perfectly.
M12-1.25 Zinc-Plated Metric Hex Nut
https://www.homedepot.com/p/Everbilt...d=887480403183
14 mm Zinc-Plated Steel Flat Washer (3-Pack)
https://www.homedepot.com/p/Everbilt...d=887480069587
12 mm Zinc-Plated Metric Flat Washer (5-Pack)
https://www.homedepot.com/p/Everbilt...d=887480024784
Caliper slider bolts (14mm) torqued to 20 ft/lb
Caliper mount bolts (17mm) torqued to 60 ft/lb
Old 08-14-2019, 10:28 PM   #14
GrantedTaken
In case I need to do this again, I am trying to remember how I REMOVED the busted stud.
Do you think I just hammered it out? I know hammering on the hub is not the best idea.
Wheel stud replacement Dave-ROR DIY (Do-It-Yourself) Guides 267 01-21-2022 08:20 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Wheel stud options chris86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-26-2014 02:40 PM
Replacement Lug Stud/Wheel Hub swift996 Issues | Warranty | Recalls / TSB 3 08-30-2013 01:58 PM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
