Old 02-10-2018, 09:39 PM   #1
razman
Drives: 2013 frs
Do FRS Aftermarket Key Fobs work?
I recently purchased aftermarket key fobs for my 2013 FRS from two different online sellers for about $20-$30 each. My original key FCC is HYQ12BBY-G and so both replacement keys I bought having matching FCC numbers. I took both keys to a couple different licensed locksmiths and they were able to cut and program the keys so that they could wirelessly open my car's door/trunk. However neither locksmith was able to program either key to start the engine. They both Independently concluded that the key I bought, while having the same FCC number, had a different series security chip or something and that I essentially had bought the wrong key. One of the locksmiths claims he can get me the right key and program it for $185. The companies that sold me the aftermarket keys are perplexed and don't see why the keys shouldn't work.
Has anyone else encountered this problem? If so do you know what cheapo aftermarket keys DO work for the FRS? I am not interested in paying $400+ at the dealer.
razman is offline   Reply With Quote
Old 02-12-2018, 02:52 AM   #2
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
The keys they sell will work but the programming is what cost the most. Last time I had lost a key I had a locksmith told me you'll need the dealer to reprogram it but went to another locksmith and he reprogrammed it for 150
turtlefeeder is offline   Reply With Quote
Old 02-12-2018, 07:38 PM   #3
razman
Drives: 2013 frs
Thanks. One of the locksmiths is willing to program the key for $65 if I provide him the key. As I mentioned though I can't figure out what after market key is the right one!
Old 02-13-2018, 07:49 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Did you take him the one you have to see if it's right?
Old 02-13-2018, 09:45 PM   #5
ermax
ermax's Avatar
I have a Tactrix cable and Techstream and have successfully paired remotes. I have not been successful at pairing the transponders though. I have a G key and the blanks I ordered were also G’s but Techstream fails to recognize them. I’m ready to suck it up and order a blank from Toyota for $60 and pair it myself. I was able to get the blades cut locally for $4.
Edit: actually I paired the remotes with an $18 cable from amazon before getting my tactrix cable. I’d buy a cheap cable before paying someone $65. My gut tells me none of these aftermarket transponders will work though.
Old 02-14-2018, 04:31 PM   #6
razman
Drives: 2013 frs
I just called Scion/Toyota here in Pasadena, CA and they quoted me $251 for a blank key. Programming it costs an additional $145. How are you able to get a blank key from Toyota for only 60 bucks?!
Paying $250 for something that costs them less than $5 to manufacture is really freaking annoying.
Old 02-14-2018, 05:53 PM   #7
ls1ac
ls1ac's Avatar
Toyota wants to program the key then the computer to work that key. Some locksmiths can duplicate the code from a working key to another making the car think it is the same key. I have done this with Lexus.
Old 02-14-2018, 07:18 PM   #8
ermax
ermax's Avatar
https://parts.toyota.com/p/Scion_201...U00303945.html
They were probably quoting you more than just the blade and transponder. This link is to the blank. The transponder is crammed into the plastic backing. I actually pried the chip out of one of the after market keys I got. Perhaps the part in my link doesn’t include the chip.
fob, key, replacement
Does satellite radio still work with an aftermarket receiver? unsurety Audio/Visual, Electronics, Infotainment, NAV 1 12-03-2014 05:54 AM
Why can't I ever get aftermarket HU dimming to work? qoncept Cosmetic Modification (Interior/Exterior/Lighting) 1 10-21-2013 09:45 PM
Does TRD diffuser work with aftermarket exhausts? sittinSideways Cosmetic Modification (Interior/Exterior/Lighting) 10 05-16-2013 12:58 AM
Alternative key fobs? post_break Scion FR-S / Toyota 86 GT86 General Forum 3 03-20-2013 12:20 PM
OEM wheel lock work on aftermarket wheels? #87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-27-2012 08:00 AM
