Old 10-21-2013, 12:37 PM   #1
qoncept
qoncept's Avatar
Why can't I ever get aftermarket HU dimming to work?
In the past 20 years I've installed about a dozen head units in several different cars. Everything has worked fine every time except I've never gotten dimming with the headlights to work. I buy the wiring harnesses, match everything up, but the illumination wire, for whatever reason, has never worked. What am I doing wrong?
qoncept is offline   Reply With Quote
Old 10-21-2013, 09:45 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
it could be a number of things..
in pioneer's for instance, there's a submenu that allows you to change weather the radio pays attention to the dimming wire or not. if i remember correctly, the oem setting is to ignore the dimming input..
but overall, my experience with MY2000+ pioneer and kenwood units is that the dimming feature just barely works-- the radio's that i've used have just barely changed intensity-- if they were at 100% brightness, they might dim down to 90% brightness..
so because of that, i never really used the illumination wire with those decks anymore, or would connect the wire, but disable the dimming feature within the radio..
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
Does TRD diffuser work with aftermarket exhausts? sittinSideways Cosmetic Modification (Interior/Exterior/Lighting) 10 05-16-2013 12:58 AM
OEM wheel lock work on aftermarket wheels? #87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-27-2012 08:00 AM
