Drives: '17 BRZ w/ PP || MBTA
Brake groan. '17 BRZ w/ PP
I've noticed a groaning sound emanating from my brakes recently. It's most noticeable when I've just started driving. The noise seems to lessen if I'm at the end of my drive. There doesn't seem to be any change in how they work though.
I have a little over 5k miles on the car. The brakes are the stock Brembo brakes that are included with the performance package. Any idea what could be causing the noise? Surface rust? Something is caught? Something is misaligned? The weather? I live in Boston in case that matters. Should I just take it to a shop? Any reason to worry at all? Video w/ sound: https://streamable.com/svfmx Last edited by Sonder; 02-06-2018 at 08:19 AM. |
Only users lose drugs.
Drives: All the time
Sounds are notoriously difficult to describe, and even more difficult to diagnose based on those descriptions alone. A 30 second listen can tell more than a whole thread's worth of writing. Where in Boston are you?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Gunshine State
Drives: '14 BRZ Limited
It's still under warranty; take it to the dealer.
![]() Current DD: M235i |
#5 | |
https://streamable.com/svfmx It sounded better today :/ Not sure if you can even hear that well in the clip. The sound is most noticeable right before I come to a complete stop. Yesterday it was much worse on that same first stop. Leads me to think it's partly weather related. |
The best thing you can do is get someone knowledgeable to take a ride with you and listen. You can usually figure it out by the end of the block.
I've noticed that these rotors will rust pretty quickly when parked...my car will typically stay parked for the weekend and by Monday morning, the first brake application is quite grumbly. It cleans up quickly though.
| Groan and Creaky Front Suspension??? | jadewbj | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 10-11-2019 01:19 PM |
| Clutch squeak, grind, groan TSB released. | Kicker18 | Issues | Warranty | Recalls / TSB | 153 | 10-01-2019 12:50 AM |
| Steering groan | gravitylover | Issues | Warranty | Recalls / TSB | 25 | 04-11-2018 09:56 PM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
