Old 02-05-2018, 02:44 PM   #1
Jkb
Drives: 2015 brz
Caster adjustment
My car was in a front end collision and has been repaired, both mechanically and cosmetically. There was minor frame damage to the frame up front and prevents me from getting my alignment back to stock. The front passenger wheel is about .5" pushed back from the frame damage. I was wondering if there is anything on the market for our cars that allows to adjust the caster so I play with the settings to get it tracking perfectly.
I was hoping this would be an option rather than making more adjustments to the frame since there is no guarantee that it will be 100% fixed.
Jkb is offline   Reply With Quote
Old 02-05-2018, 02:53 PM   #2
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
i think there are some front plates are allow adjustment to caster.
I think raceseng is one of them
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 02-05-2018, 02:54 PM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Check this:
http://www.whiteline.com.au/product_..._number=KCA434
It adds +0.5deg static caster, but it should be a temporary solution. Dynamic caster will be different and not optimal.
Old 02-05-2018, 04:14 PM   #4
Jkb
Drives: 2015 brz
Originally Posted by nikitopo View Post
Check this:
This just be what Im looking for.
Thanks!
Old 02-06-2018, 11:14 AM   #5
wparsons
wparsons's Avatar
Was the car repaired by insurance? If the wheel is still pushed back, it wasn't fixed properly and should be taken care of by the shop that "fixed" it. If they can't straighten the frame back within factory specs, then it should either be written off or taken to a competent shop.
flickr
The Following 7 Users Say Thank You to wparsons For This Useful Post:
Cole (02-06-2018), ls1ac (02-06-2018), Lust (02-06-2018), nocoolname (02-06-2018), strat61caster (02-06-2018), Tcoat (02-06-2018), TofuJoe (02-06-2018)
Old 02-06-2018, 03:09 PM   #6
Cole
Not a troll
Cole's Avatar
That's what I was about to say.
Doesn't sound like the car was fixed.
Old 02-06-2018, 06:09 PM   #7
nocoolname
Like the others said, whoever fixed it, did a poor job. If you paid for a correct repair or it was an insurance job then take it back. If you went with somewhere cheap or a buddy deal, then that's your fault and it should be fixed correctly.
Don't use the whiteline parts, that's putting a bandaid on a gun shot wound as it's only treating a symptom and not fixing the problem.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
The Following 2 Users Say Thank You to nocoolname For This Useful Post:
Tcoat (02-06-2018), wparsons (02-07-2018)
DIF Top Hats -- Caster/Camber Adjustable, Caster Adjustable, and Coaxial Rear FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-19-2017 01:43 PM
different caster setting marcom Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-23-2017 03:42 PM
Uneven Caster smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-03-2016 11:12 AM
Caster adjustment FReeSky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-14-2016 09:19 PM
Rear Caster Adjustment Questions RWDRIFT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-05-2012 11:47 AM
