Old 03-14-2016, 12:42 AM   #1
FReeSky
Drives: Stormtrooper
Caster adjustment
Im having issues with clearance on my front wheels, running some wide tires so the my tires are hitting the back of my fender, i need about an inch of space, thought maybe getting a positive caster would help, I was going to call an aligment shop tomorrow to see about it figured id post it here first maybe I can get some feedback to help me thanks!
FReeSky is offline   Reply With Quote
Old 03-14-2016, 08:06 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Caster moves the strut forward a backwards (parallel to the side of the car) and will not give you any clearance.
Old 03-14-2016, 08:49 AM   #3
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
I doubt caster would get you what you need, and the cars stock don't have a caster adjustment, you would need an adjustable bushing for the lower control arm.
Gear_One_Performance is offline   Reply With Quote
Old 03-14-2016, 12:47 PM   #4
FReeSky
Got it, you don't think having a positive caster would give me a better turning angle that doesn't hit the back of the fender? I thought about smaller tires, not sure what to do right now here's a pic
Old 03-14-2016, 12:55 PM   #5
FReeSky
Old 03-14-2016, 01:32 PM   #6
wparsons
wparsons's Avatar
What size wheels/tires?
flickr
Old 03-14-2016, 04:51 PM   #7
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 6 Users Say Thank You to Hyper4mance2k For This Useful Post:
8R6 (03-14-2016), Calum (03-14-2016), Chrisgalactic (03-15-2016), go_a_way1 (03-14-2016), smg1138 (03-14-2016), wparsons (03-14-2016)
Old 03-14-2016, 04:59 PM   #8
8R6
8R6's Avatar
Drives: FRS
is this shot of the back of the front tires and the fender (not the front side of tire where the bumper is)?
if so, it looks like your tires are mounted backwards too.....
8R6 is offline   Reply With Quote
Old 03-14-2016, 05:03 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
An inch of positive caster not only will not help, it will just be worse than what you have now.
Looks like you are trying to run wide wheels... not sure who has told you this will work but one major drawback of wide wheels is that you will rub at full lock.
Live with it or get smaller wheels.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
86kahl (03-14-2016)
Old 03-14-2016, 06:32 PM   #10
FReeSky
Left & right wheel were swapped, not going smaller wheels or tires. Cutting it where its hitting and molding it back a little/ nobody told me it'd work, you live and you learn
Thanks
Old 03-14-2016, 07:12 PM   #11
Ashikabi
Ashikabi's Avatar
Thanks
I suppose adjustable front LCA could help, push the button of the wheel out. Gonna be spendy though. Cutting is the cheap way out. Can't say I blame ya, I had some that rubbed at full lock too
Old 03-14-2016, 08:38 PM   #12
FReeSky
If LCA would fix my problem id definitely get it but I don't think it will with the amount of space I need. I found a body shop that are cutting and molding the skirt/fender back a little which won't be cheap either but it might be the way to go
Old 03-14-2016, 09:02 PM   #13
Ashikabi
Ashikabi's Avatar
It'd be some pretty heavy camber for sure. You could just widebody I guess, then this wouldn't be a problem
Old 03-14-2016, 09:16 PM   #14
FReeSky
It's already a rocketbunny ��
WTB camber/caster plate scionfr_s Want-To-Buy Requests 3 02-28-2016 04:31 PM
Caster off, is this causing the problem? dem00n Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 07-18-2015 11:31 AM
Caster, SAI, Steering and Camber Wepeel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-24-2015 08:09 PM
Adjust camber/caster from top or bottom? diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-22-2014 04:03 PM
Rear Caster Adjustment Questions RWDRIFT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-05-2012 11:47 AM
