Old 08-23-2017, 11:46 AM   #1
marcom
Drives: toyota 86
different caster setting
Hi Guys,
My car had a minor accident a few months back and I just got it a few days ago. I got an alignment and found out that my left caster is off from factory setting.
here are the results:
camber L: -0°59 (requested for this settings)
camber R: -1°00 (requested for this settings)
caster L: 3°52
caster R: 5°44
toe L: 0°00
toe R: 0°00
my questions are:
1. how will this caster setting affect the performance of the car? I have not tried going beyond 40mph as of the moment and for me the car feels normal at slow speed.
2. what can I do to correct this?
btw, im using bc coilover with an inch drop
thanks in advance!
marcom is offline   Reply With Quote
Old 08-23-2017, 12:04 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
From ways to adjust caster that i know - Whiteline LCA bushings KCA434 (+0.5dg caster) and raceseng cascam plates (don't know the range). But sill .. i'm thinking, that accident damage wasn't repaired completely, and some parts left bent. Imho difference of caster should be less then 1.1dg you have.
As for camber .. your BC coilovers don't have camber plates in set to even it out?
Old 08-23-2017, 12:10 PM   #3
marcom
Drives: toyota 86
the camber is adjustable in the BC coilover. I asked for those settings
Old 08-23-2017, 03:42 PM   #4
wparsons
wparsons's Avatar
Curious as to why you want asymmetrical front camber...
As for the caster, it looks like something wasn't fully repaired, was the car hit on the front left? How hard was the hit?
flickr
DIF Top Hats -- Caster/Camber Adjustable, Caster Adjustable, and Coaxial Rear FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-19-2017 01:43 PM
Uneven Caster smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-03-2016 11:12 AM
Caster adjustment FReeSky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-14-2016 09:19 PM
Caster off, is this causing the problem? dem00n Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 07-18-2015 11:31 AM
Caster, SAI, Steering and Camber Wepeel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-24-2015 08:09 PM
