Old 02-04-2018, 06:53 PM   #1
norcalpb
norcalpb's Avatar
Intense Brake Squeal!
Hi guys,
I installed Carbotech AX6 brake pads 10k miles ago and I don't think I did the bedding process correctly (I applied ABS, and only did the 0-60-0 about 6 times and there was probably 2 min between each 60-0. Long story short I have a horrible squeal and what sounds like pads rubbing when I'm not even on the gas pedal.
My question is what is the best way to eliminate this noise? Can I try to re-bed my brakes, or is the original bedding layer already gone and this would be futile? I have removed the brake shims.
If the pads are toast I assume I would new pads, but would the new centric rotors be ok?
This has been bugging me for a while so any and all help is appreciated!! I also would be looking for pad suggestions that are less intense than AX6.
Old 02-04-2018, 07:36 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Re-bedding should fix it for a time - repeat as needed. It won't be permanent, but can last quite some time if you get the procedure right for the setup you have. Are they quiet for the first few stops? Or are they always noisy?
I haven't yet found a procedure that gives me more than a handful of quiet stops. Mine are quiet when cold, though. The procedures that are recommended are impossible for me to do without quite a long drive, and I never think of it when I'm already somewhere I could try it. Some day.
C
The Following 2 Users Say Thank You to cjd For This Useful Post:
norcalpb (02-04-2018), strat61caster (02-05-2018)
Old 02-04-2018, 07:40 PM   #3
FirstWinter
Drives: Car
Okay first I would inspect your brakes thoroughly and try to find if there is a more serious issue behind the noise you are hearing. Is this noise occurring only when doing a certain thing with the car? (Under braking, when turning, etc) A recording of the sounds would be great too if you're unsure if the cause of the sound is actually just the pads needing bedding.
You also have to regularly bed brake pads. The transfer layer goes away over time.
You should regularly inspect your brake pads & calipers anyways. You'll be fine if you swap pads but reuse the rotors. You'll have to bed the new pads obviously.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Old 02-04-2018, 07:55 PM   #4
norcalpb
norcalpb's Avatar
C
They're only noisy at lower speeds, and sometimes I can press the brake pedal slightly more and the noise just goes away completely as long as I keep that specific pressure on the brake. Mine also don't squeak when it's cold, and I have tried to the re-bed procedure multiple times but sometimes the noise comes back after days. I guess I just need to do more 60-0s.
Thank you for your input.
I only hear the brake rubbing noise when I'm driving straight. I have noticed that when I re-bed the noise goes away for a while, but it'll eventually come back. Should I be braking more during low speed daily situations? I tend to engine brake and maybe that causes the transfer layer to go away quicker? I also do about 20k miles per year so I am driving a lot in daily situations. Thank you for your input.
Old 02-04-2018, 08:04 PM   #5
FirstWinter
Drives: Car
From what you're saying the pads sounds normal. Even with bedding when pressing gently/lightly on the brakes there's a bit of noise. I just live with it because braking harder is going to spill my coffee everywhere when I'm driving on the street lol
Old 02-04-2018, 08:51 PM   #6
After 10K they should be bedded fine even with regular driving. You say they are noisy even when just driving and not on the pedal? Is it all the wheels? One or more pads are just loose?
Teseo (02-05-2018)
Old 02-04-2018, 08:56 PM   #7
cjd
cjd's Avatar
Drives: 2017 BRZ
It's an autocross oriented pad and everyone I've talked to says it's on the noisy side. Where there is inconsistency is in how long people get them to be quiet. I can think of a few that gave up on the pad because it didn't meet their 'street and autox' needs well due to the noise.
C
The Following 3 Users Say Thank You to cjd For This Useful Post:
strat61caster (02-05-2018), Tcoat (02-05-2018), Ultramaroon (02-11-2018)
Old 02-04-2018, 08:59 PM   #8
norcalpb
norcalpb's Avatar
I'm thinking it's the front brakes that make the whisking brake noise when I'm driving normally. And I checked all bolts for tightness about 5k after the install and everything was fine.
I think this all might be normal for the pads as I wasn't thinking when I ordered pads that were partly made out of metal lol. If I could choose again I'd go with a less intense pad.
The Following User Says Thank You to norcalpb For This Useful Post:
Tcoat (02-05-2018)
Old 02-04-2018, 09:01 PM   #9
norcalpb
norcalpb's Avatar
C
That makes sense, I think this is just a case of me buying too much pad for what I would use them for. They do feel great when they are hot though!
Old 02-05-2018, 08:54 AM   #10
stevesnj
stevesnj's Avatar
You experiencing colder weather lately? Cooler weather and high performance pads have the effect of squealing.
My 2016 Build thread
Old 02-05-2018, 01:22 PM   #11
Qadthane
Qadthane's Avatar
Drives: 2013 FR-S in Asphalt
Try putting the shims back on. It made a world of difference on my Project Mu HC+ 800 pads.
Qadthane is offline   Reply With Quote
The Following User Says Thank You to Qadthane For This Useful Post:
Tcoat (02-05-2018)
Old 02-05-2018, 02:09 PM   #12
That is sort of what I was getting at.
Old 02-05-2018, 04:31 PM   #13
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Also, nobody mentioned brake grease, but did you use some? You need to put that stuff between the pad and the shim, and between the shim and the caliber and also on the retaining clips. This help a lot with the squealing. Use something high quality. Obviously make sure you don't get any on the pad surface and on the rotor
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
Tcoat (02-05-2018)
Old 02-05-2018, 05:32 PM   #14
norcalpb
norcalpb's Avatar
Yes I did use grease but not on the retainer clips. I’ll order new shims.
Do I have to cake both sides with grease or can I leave the exposed part of the shim clean so it doesn’t make it look bad?
2017 brz PP brake squeal! tfp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-25-2017 04:02 PM
Brake squeal while coasting ryoma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-28-2016 06:34 PM
Brake Squeal bg15 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-27-2016 10:51 AM
Brake Squeal Maritime Storm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-01-2015 10:59 AM
Intense rear wheel shudder during e-brake drifts SkAsphalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-09-2014 01:05 PM
