Old 10-28-2016, 06:34 PM   #1
ryoma
ryoma's Avatar
Brake squeal while coasting
this problem has stumped me for a while. I get intermittent brake squeal when coasting and slight throttle. the brakes don't squeal when braking, but only when I am in motion either coasting or partial throttle (does not squeal under full throttle). I have used a wire brush to clean my calipers as well as applied anti-squeal on top of the shims. I am basically stumped right now. I have Winmax W5 pads and stock rotors, though the front rotors have a slight lip on the outer edge of the rotors. could that edge be contacting the pads and causing the squeal? the squeal is only intermittent though, so I do not think that is the problem. I am thinking somehow the pads are sticking so does that lead to a caliper problem? I have made sure that the caliper sliders (the thin sheet metal pieces where the pads slot into) are clean of brake dust.
Brake Squeal bg15 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-27-2016 10:51 AM
Brake Squeal Maritime Storm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-01-2015 10:59 AM
Coasting, brake riding, engine braking paulca Scion FR-S / Toyota 86 GT86 General Forum 17 08-24-2014 05:53 PM
Coasting? Ben_G Engine, Exhaust, Transmission 22 03-22-2013 02:36 AM
Coasting into the gas station? bdanisi Scion FR-S / Toyota 86 GT86 General Forum 28 03-07-2013 08:16 PM
