Old 01-29-2018, 02:55 PM   #1
arren123
Drives: 2013 BRZ (RIP), now 2017 BRZ
2017 BRZ Cracks on Timing Cover is this normal?
This is on a new 2017 BRZ Limited manual with 1050 miles on it.
Is this normal? See all the cracks on the timing cover? It's on the the other half of the cover as well.
The cracks are rough. When I tried wiping it down with a blue shop towel it was tearing the towel. I don't remember seeing anything like this on any car I owned before.
arren123 is offline   Reply With Quote
Old 01-29-2018, 03:02 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
Looks like a flaw from the cast.
jasonojordan is offline   Reply With Quote
Old 01-29-2018, 03:16 PM   #3
Newtothegrounds
Newtothegrounds's Avatar
Drives: 2016 FRS
I have the exact same on mine as well, just saw it the other day. I have 2016 with 10k on it. Not sure if it's a good, bad or doesn't matter thing.
Newtothegrounds is offline   Reply With Quote
Old 01-29-2018, 03:29 PM   #4
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Typical pour casting surface after cooling.
The outside doesn't need to be smooth so they don't bother machining it.
As long as there is no water or oil seeping out, it's a reflection of the low price paid for a new twin.
Old 01-29-2018, 04:46 PM   #5
arren123
That is pretty lousy if they just left it unfinished. Not the typical quality that I expect from a Japanese car.
Old 01-29-2018, 05:04 PM   #6
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
^This, if there's a leak, bring it back to dealership and get it replaced.
I'll double check mine, but I think it was pretty smooth.
Yeah, I'm surprised to see these kind of thing now days. I know Subaru doesn't have a high quality... but this is pretty bad.
Old 01-29-2018, 05:05 PM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
American engine blocks were all sand cast and left rough on the outside since forever.
Only a few specialty billet machined blocks have ever been produced (relative to stock).
You can spend the time to file it all pretty, or you can pay a much higher price for the new vehicle.
My Alfa engine block from the 70's looked like this on the outside too.
They were considered cheap cars back then as well. Didn't stop them from being fun to drive.
Old 01-29-2018, 05:22 PM   #8
ermax
ermax's Avatar
Yeah this is fairly typical of any cast aluminium piece. No need to machine the exterior of a timing cover. It isn't for decoration.
Old 01-29-2018, 09:14 PM   #9
humfrz
Just don't do that no more ....... that part don't need wiped off.
Like others have said ..... as long as it ain't leaken .... no problem.
humfrz
Old 01-29-2018, 09:21 PM   #10
arren123
humfrz
Ha! I wanted to see if the cracks were just water stains. The engine was still hot so I didn't want to touch it with my fingers.
No leaks, so I should be good.
Old 01-30-2018, 08:15 AM   #11
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Damm now Ima have to check mine out and see.......probably look the same.
As others have stated no leaks no problems
22R
22R is offline   Reply With Quote
Old 01-30-2018, 09:45 AM   #12
Tokay444
Anti stance.
Tokay444's Avatar
Why is this bad exactly? Do you have any idea how much MORE cost would be added to that part if they machined the entire outside surface, instead of just the mating surfaces?
Old 01-30-2018, 09:47 AM   #13
My first job when I left the army was at an aluminum casting plant. I believe the covers are die cast not sand cast but it can be very hard to tell sometimes. Either way surface checking like the picture shows is from the mold binging slightly cold. It only affects the outer surface and happens every time there is a delay in a pour. Nothing to worry about since it just means the casting was made early in the shift or right after a break.
Old 01-30-2018, 09:49 AM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
Function wise, nothing wrong. Visual wise, pretty bad. Japanese brand used to worry about these small things. That’s what made Japanese car quality standard different than other country’s cars.
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 4 04-03-2018 03:06 PM
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 5 12-16-2017 03:19 PM
Timing Cover Oil Leak AllDayJonRay Issues | Warranty | Recalls / TSB 18 06-06-2016 03:12 AM
Timing Cover Oil Leak Keenercarguy Issues | Warranty | Recalls / TSB 66 05-30-2016 11:59 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
