Old 04-30-2015, 07:29 AM   #1
raven1231
WORKS Motorsports Turbo Kit Experience
So, after much going back and forth, I decided on the WORKS Turbo kit. I know the haters out there will bitch and moan, but for the money, reliability of the components, ease of install, and power levels that I'm looking for it's a no brainer.
I will be ordering this next week! Those who are interested or on the fence about this kit stay tuned! I'll be updating this thread with progress pics from delivery, install, dyno, driving experience and feedback throughout the whole process.
Plan is to run the following-
  • WORKS Turbo Kit
  • Borla UEL header
  • MANZO Catless Front Pipe
  • MANZO Over Pipe
  • Ikon Motorsports Cat Back Exhaust
  • Vent Pod AEM Wideband/Boost Gauge
  • Open Flash Tablet E85/93 octane
Old 04-30-2015, 08:56 AM   #2
erbaker67
erbaker67's Avatar
Drives: 2015 FRS RS1, 93 Supra
Looking forward to it!
erbaker67 is offline   Reply With Quote
Old 04-30-2015, 09:54 AM   #3
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I truly hope you are getting the one with the a2w intercooler.
hmong337 is offline   Reply With Quote
Old 04-30-2015, 10:07 AM   #4
raven1231
And it begins....lol
Old 04-30-2015, 10:58 AM   #5
hmong337
Emperor JDM
hmong337's Avatar
I hate to be THAT guy but being around turbocharged mr2's my entire life, I think I know a little bit about proper intercooling. Good intercooling is VITAL to a reliable setup.
I wish you all the best on your blow-through setup. I seriously would love to be proven wrong. Especially on a car that is known to run hot even WITH proper intercooling.
Cheers.
Old 04-30-2015, 11:46 AM   #6
wparsons
wparsons's Avatar
Mid engine cars with minimal airflow to an intercooler are slightly different than front engine cars with a big opening for a good air to air intercooler...
Air to water intercooling isn't going to drop under hood temperatures either. All turbo'd cars are going to need oil cooling, and everything you can do to manage underhood heat. Coat the exhaust parts, wrap them, turbo blanket, etc.
flickr
Old 04-30-2015, 12:14 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
hey i heard you like intercooling, heres an intercooler for your intercooler so you can internally cool while your cooling internally
Old 04-30-2015, 01:01 PM   #8
hmong337
Emperor JDM
hmong337's Avatar
Well that's my point. Mid-engine cars suffer from poor intercooling. Even with my upgraded Greddy SMIC, it's only mediocre at best. I'll either have to cut out my trunk to lay a large intercooler in there (not willing to do this!), or run an a2w setup (which I am currently piecing together).
Have you seen the stage 1 Works kit? Front engine or not, it lacks an intercooler. I hope to god you're not gonna argue with me over this. The turbo will blow nothing but hot air! In a strict drag setup, sure. But anything else all I see is trouble. At the very minimum you should be running WMI if you're going non-intercooled.
Old 04-30-2015, 01:02 PM   #9
raven1231
Cheers.
Might upgrade later down the road. However the tuners that have installed them so far said heat wasn't an issue.
Old 04-30-2015, 01:07 PM   #10
stevo585
Drives: White 2014 BRZ
At low boost on e85 you should have no issues imo. Its essentially chemical inter cooling with e85.
stevo585 is offline   Reply With Quote
Old 04-30-2015, 01:10 PM   #11
hmong337
Emperor JDM
hmong337's Avatar
...yet, there's a 100 page topic about "combating heat". And, everybody who is turbo is running into heat issues unless they've addressed everything.
Don't get me wrong, I like this kit WITH the a2w setup. I would never do the stage 1 though. AIT's are probably scary!
Old 04-30-2015, 01:44 PM   #12
raven1231
If it becomes an issue then I will upgrade
Old 04-30-2015, 01:46 PM   #13
Apples and oranges, but compare the innovate intercooled vs non-intercooled.
Old 04-30-2015, 01:48 PM   #14
Last time I tried to discuss this....
Originally Posted by Moderator
Dear CSG Mike,
You have received a warning at Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB.
Reason:
Violation of Forum Rule(s)
Hello, please review the posted site rules.
"Do not comment on any other vendor/sponsor's company, products, or services. Stick to discussing only your own. This applies forum-wide and not just the classifieds."
Thank you for your compliance.
Original Post:
https://www.ft86club.com/forums/showthread.php?p=2055464
Originally Posted by WORKS View Post
That's a valid concern we have addressed. The exhaust piping included in our kit is ceramic coated which cuts down on radiant engine bay heat significantly. We use a battery heatshield (included in the kit) and have monitored battery surface temperatures after track sessions and have found them to be a non-issue when using the heatshield. We did see some slight heat effects on the thin plastic battery tray after extended track sessions so we redesigned our heatshield to cover the tray as well. The injector ECU showed no heat effect. We provide thermal wrap in our kit to protect all wiring in the area of the turbo.
Cheers.
We've melted fans with exhaust manifolds that are both Ceramic coated AND wrapped AND heat shielded. Are you sure that's enough?
You guys use thermocouples; what kind of EGTs were you seeing with your tune, and what was the temperature of the surface of your battery, heat shield, and exhaust manifold after a session on track?
Warnings serve as a reminder to you of the forum's rules, which you are expected to understand and follow.
All the best,
So, I will be stepping out of this thread now, lest someone become offended that I'm questioning their product in the matter that I question all products.
King Tut's Full Blown Motorsports Stage 1 Base Turbo Kit Experience King Tut Forced Induction 196 09-04-2016 09:47 AM
Cosworth Stage 2.0 In-Stock! WORKS Motorsports WORKS Forced Induction 37 07-28-2015 08:18 PM
Hello from WORKS Motorsports! **10% discount for FT86club members!** WORKS Northern California 35 05-22-2014 01:20 PM
Hello from WORKS Motorsports! **10% discount for FT86club Members!** WORKS Announcements, Contests, Giveaways 1 04-16-2014 10:04 PM
Stainless Works, experience? Nourdmrolnmt1 Engine, Exhaust, Transmission 7 05-18-2013 04:07 PM
