Old 01-18-2018, 01:38 PM   #1
Eris-time
Drives: Fast looking but slow
Which turbo kit fits my needs?
Hi there,
I am looking for a turbo kit for my car and i'll keep things simple
-looking to spend the least $$$
-the turbo will be straight up just for looks
-230whp is the most I want
-exhaust? I cut out the 2nd cat, and aim to get UEL headers...
-trying to change the least amount of parts possible
the reason for all of these reasons is because I want the car to have the least amount of maintenance/greatest amount of reliability possible - and I don't mind less hp because of it.
Eris-time is offline   Reply With Quote
Old 01-18-2018, 01:48 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
SBD or JDL. Only thing is that you won't have the option of UEL with the SBD.
Only UEL turbo kits I know are AVO and JDL. AVO is not top mounted so it's not going to have the "straight up just for looks" factor you're going for.
tyler_win_photo is offline   Reply With Quote
Old 01-18-2018, 01:49 PM   #3
Fred E
Drives: WRB BRZ
The cheapest UEL turbo kit is the JDL ($3300 at the new price/new base turbo). The other options are AVO ($$ - $4500) and Ptuning with any UEL header ($$$$ - $5800 + the cost of the UEL header). You would just run it with the weakest wastegate spring possible for the least amount of boost and let your tuner know that you want it as conservative as possible.
Fred E is offline   Reply With Quote
Old 01-18-2018, 01:58 PM   #4
S. Snake
S. Snake's Avatar
Drives: 13' Asphalt
From when I was looking for a turbo I was looking at the WORKS turbo kit, it's tuned and CARB compliant but compared to cars that come turbo from the factory it it just seems like there really isn't enough space anywhere in the engine bay besides in front of the engine for a turbo. Also keep in mind the cost of tuning for any of the other kits and you're gonna have to have a oil return line into the oil pan on the motor and turbos get hot. Ultimately in the end I personally REALLY wanted a turbo but since I like driving my FR-S daily I opted for a supercharger, less maintenance, don't have to worry about heat management and I don't have to worry as much about keeping the boost in check. Lastly I suggest you take a long hard read at some of the turbo kit owners threads to get a realistic idea of what it's going to be like installing the turbo and living with it on the day to day. Good luck in whatever you choose to do!
S. Snake is offline   Reply With Quote
Old 01-18-2018, 02:02 PM   #5
Cole
Not a troll
Cole's Avatar
Why not just get an intercooler to put behind your bumper, and never pop the hood?
Old 01-18-2018, 02:04 PM   #6
Icecreamtruk
Drives: Track preped NA FRS
To add to @Cole 's answer:
[ame="https://www.youtube.com/watch?v=Z_fG_b65WiU"]https://www.youtube.com/watch?v=Z_fG_b65WiU[/ame]
Old 01-18-2018, 02:23 PM   #7
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
If you are concerned about CARB being in CA, then dont remove any cats and run a SC.
If you want reliability run the JSRC. Dont run a turbo. It's more maintenance.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 01-18-2018, 03:03 PM   #8
jasonojordan
Drives: 2013 satin white brz limited
IF you want to change as little parts as possible plus make the car easily turned back to stock your power goal is very obtainable with a supercharger kit.
Perhaps consider that. Also the just for looks comment is really confusing...
jasonojordan is offline   Reply With Quote
Old 01-18-2018, 04:30 PM   #9
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
@Cole with the real answers.
If you absolutely must have a turbo and you must have UEL sound, just get JDL V2 with no options and call this thread done.
I mean... by what measure? I don't have to worry about belts or an LTR cooling loop anymore, and I'm checking my oil regularly anyway. I always hear this argument and then wonder what the shit people are doing that requires so much "turbo maintenance".
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 01-18-2018, 04:44 PM   #10
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Uhh, wut?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 01-18-2018, 04:56 PM   #11
tennisfreak
Drives: 2018 BMW M240i
Edelbrock Supercharger and done.
Carb compliant, 240whp, 100000 mile maintenance interval, retain warranty
Old 01-18-2018, 04:59 PM   #12
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
get a works stage 2...
Hi there,
Just get a works stage 2 and use any uel header you want, since it uses the stock header, you can use any header that mounts in the same location.
Hell you'll also get the power you're looking for with the standard tune and you can just use the tactrix for it which it comes with for no extra charge on the carb kit.
Jaden
Jaden is offline   Reply With Quote
Old 01-18-2018, 05:02 PM   #13
Fred E
Drives: WRB BRZ
Yeah, a turbo setup seems like less maintenance, if anything...
Old 01-18-2018, 05:08 PM   #14
Teseo
Drives: frs
Add oil cooler, maybe big rad... thats a grand there
Which intake fits my requirements? OkieSnuffBox Engine, Exhaust, Transmission 33 05-16-2015 04:31 AM
FS: OEM FRS mudguards (fits BRZ) 1Cor10:23 Canada Classifieds 1 05-22-2014 11:32 AM
(SOLD) DEI Turbo Blanket (fits AVO Kit and similar sized turbos) Sportsguy83 Engine, Exhaust, Bolt-Ons 1 10-24-2013 10:34 AM
Which Drop-in filter fits the best? BlackyRose Engine, Exhaust, Transmission 25 06-22-2013 03:30 AM
BRZ Gas Lid Fits on FR-S? 914_WHITE_FRS FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 06-20-2013 05:08 PM
