Drives: 2017 SUBARU BRZ
FOG LIGHT SWITCH FOR 2017 BRZ
I recently installed the Winjet fog light kit on my BRZ Premium and I noticed all the OEM wiring harness is already on the car. I went ahead and used the winjet wiring and switch. Do any of you know if I can use the winjet switch with the OEM harness? I tried taping into the black & yellow/ white & grey wires using the winjet switch but NO CIGAR.
I also followed the following video: Here are pictures of the wiring. The winjet is red, yellow and black. ![]() OEM fog light wiring(as shown on video):
Maybe I just need a 2 pin switch like shown on the video ???
Drives: 2017 Toyota 86 (Black)
So I got a kit off of eBay. I have a 2017 Toyota 86 and luckily the pre wiring fits they headlights... I needed some hardware to mount, but that’s not a big problem. Anyway the two wires in the video are pretty much the hot and neutral. The other wires may be for dimming (I really don’t know). But a 2 way switch should work, just get some wire taps like the video and hook it up to your 2 way switch of choice. I hope that helps.
ProCrastinationConsultant
You should be able to get a switch off ebay. I did from another toyota.
Do not just use a 2 pole switch. Half of the wires are for button illumination, the other half are for fog light power/control. A 2 pole switch will short the illumination portion. Did you check that the fuses exist in either fuse box? |
| So where will the fog light switch go... | Asphalt | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 04-08-2019 07:09 PM |
| Frs stalk with fog light switch | chriscross_tnt | Audio/Visual, Electronics, Infotainment, NAV | 1 | 04-09-2015 06:36 PM |
| FS OEM Light switch/stalk | Trashed675 | Interior Parts (Incl. Lighting) | 0 | 04-07-2015 03:31 PM |
| Where is your Fog light switch? | SillySaxon | BRZ First-Gen (2012+) — General Topics | 10 | 07-11-2014 10:51 AM |
| How to wire a fog light switch to Diode Dynamics fog light kit *SOLVED | tiz22 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 06-04-2014 01:16 AM |
