Old 10-01-2012, 10:25 AM   #1
Asphalt
So where will the fog light switch go...
On the BRZ it is on the turn signal stalk I think. But the FRS doesnt have that. I thought maybe the button would go next to the trunk release, but there isn't a cutout for a button.
Ideas? Maybe thats why its taking a while to come out
Asphalt is offline   Reply With Quote
Old 10-01-2012, 11:22 AM   #2
connor_lol
connor_lol's Avatar
Drives: GT86 / Rebadged Firestorm FRS
I thought on the BRZ it was next to the trunk release. It's a dummy on the FRS right now
connor_lol is offline   Reply With Quote
Old 10-01-2012, 11:34 AM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Ours(nissan) usually come with a new headlight switch in the kit.
JoeBoxer is offline   Reply With Quote
Old 10-01-2012, 12:11 PM   #4
CrazyWookiee
Fog lamps for the BRZ and FR-S are on the turn signal stock.
BRZ Premium without Fog Lamps:
BRZ Limited with Fog Lamps:
GT86 with Fog Lamps:
The switch next to the trunk release is for adjusting brightness of HID's, hence exclusion of it from the FR-S:
Edit: It's for leveling of the headlamps.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 10-01-2012, 12:25 PM   #5
Asphalt
safe to say then that the fog light kit will include a new stock. seems like a little bit of a pain to install. maybe someone with more experience with this could input
Old 10-01-2012, 12:27 PM   #6
truenosan
truenosan's Avatar
Drives: 13 Firestorm FRS
It isn't all that difficult to install. Subaru has been doing this for years on their cars. You could buy a foglight kit for the STi, and it is pretty much plug and play.
To change the stalk, you pop the steering wheel off usually, and it's pretty straight forward from there.
truenosan is offline   Reply With Quote
Old 10-01-2012, 12:51 PM   #7
colHolm
Default User Title
colHolm's Avatar
That's actually for levelling the headlights.
colHolm is offline   Reply With Quote
Old 10-01-2012, 01:01 PM   #8
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Hence the lack of the "bulb symbol" like the one depicting instrument panel brightness. Does any vehicle let one "adjust" fog lamp brightness?
Wolfking is offline   Reply With Quote
Old 10-01-2012, 02:06 PM   #9
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
I've done the install you drill out a hole next to the trunk release. You have to do it near there since you tap into wires already there.
SubaSteve is offline   Reply With Quote
Old 10-01-2012, 02:06 PM   #10
Asphalt
Why are there two symbols of fog lights on the gt86 stalk?
Old 10-01-2012, 02:13 PM   #11
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Rear fogs outside of us.
Old 10-01-2012, 02:16 PM   #12
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
The other symbol is for the rear fog light...the red triangle between the back up lights.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 10-01-2012, 02:23 PM   #13
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Sucks because you have to drill out a hole and our dremel is stuck at max speed..... Had to go get a washer to fill the edges.
You tap into the white wire with blue tape on it.
Old 10-01-2012, 05:22 PM   #14
CrazyWookiee
Oops. Thanks for pointing that out. I was just making an educated guess.
Permanent Traction Override Switch DarrenDriven DIY (Do-It-Yourself) Guides 197 07-14-2020 11:03 AM
GT86 foglights installed but no switch? derka-derka Electronics | Audio | NAV | Infotainment 8 08-16-2013 03:13 PM
Switch to Subaru center caps? SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 08-26-2012 10:21 PM
LF: rear fog switch picture Silverdub Scion FR-S / Toyota 86 GT86 General Forum 6 06-28-2012 08:34 AM
Anyone going to switch badges? DougieFresh Scion FR-S / Toyota 86 GT86 General Forum 60 09-28-2011 02:56 AM
