Old 01-11-2018, 10:50 PM   #1
Brz_racer
Drives: Subaru BRZ
Dome Light Issues
So last year i installed an LED Dome light and also LED Light Strips on the driver and passenger side that are wired to the dome light so anytime you open the door they all come on. Within the past month and a half the dome light started flickering and jiggling the switch would usually fix it. However as of the past week it now does not work at all. I checked all the wiring and its good, the only thing i can think is that the dome light switch has finally gone bad. Anyone have a similar issue or have any other suggestions as to what I could try?
Brz_racer is offline   Reply With Quote
Old 01-11-2018, 11:13 PM   #2
norcalpb
norcalpb's Avatar
Take apart the dome light and remove the switch. You’ll see 3 leads that the switch runs over and you just need to bend those back so they have a more firm connection on the switch.
Old 01-11-2018, 11:27 PM   #3
Brz_racer
Drives: Subaru BRZ
Okay, ill give this a try, i guess worst case i need to replace the dome light assembly, I was reading about how people were frying the BIU with LED's but i dont think thats whats going on here.
Old 01-12-2018, 12:16 AM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I have a Diode Dynamics led dome light. Lately it has been not working. Sometimes it is on. Sometimes it is off. Sometimes it seems dim. I can remove the shield and twist the LED light, and it will turn on. I figured the light could be bad or the connection was poor. I have yet to replace the LED light with the stock bulb to test if it is the LED light or to rule out a bad connection.
Old 01-12-2018, 12:53 AM   #5
Brz_racer
Drives: Subaru BRZ
Yeah the aftermarket bulbs seem to be hit or miss, especially the ones with the cheapass plastic adapter with the spring
Old 01-12-2018, 04:24 PM   #6
Brz_racer
Drives: Subaru BRZ
Loose connection was the cause in case anyone was curious i moved the adapter and the lights came on, just wasnt secured in the slot properly
Old 01-15-2018, 02:49 AM   #7
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Been buying LEDs since 2014 on different cars from Ijdmtoy, superbrightLEDs, diodedynamics, vleds, TRS, xenondepot.
I can only say that VLEDs are the only ones that have never died on me so far.
Basic rule i found out is dont get marketed over really high power LEDs. stick with low power long life ones. Also makes the car look more OEM.
leevanf is offline   Reply With Quote
Old 01-15-2018, 04:30 AM   #8
tina144
Drives: 2015 SCION FRS AUTOMATIC
Hi, so I just got a 2015 frs. Do you know why the LED/HID headlights flicker? It's not necessarily a on and off switch, its more of a rapid motion that the light makes.. it's only on one side. I found some guy off of instagram/yelp.. seemed legit & he came back the 2nd time to replace the bulb of the headlight. Now its happening again >.< ! However, the only time it does this is when my light switch is turned to the bottom " o " symbol or the two lights facing eachother symbol. I do apologize on my lack of knowledge when it comes to cars, but signing up to this forum is the step in right direction. -K
tina144 is offline   Reply With Quote
Old 01-15-2018, 04:56 AM   #9
spike021
spike021's Avatar
Random question: is the weather usually cold/damp when this happens?
I had installed a dome light board LED from diode dynamics several months ago and noticed it wouldn’t work if the temperature was roughly 45 F and lower as well as the air being damp.
Finally replaced it the other day and it seems to be working properly in that environment now (will need to keep testing it the next few weeks).
spike021 is offline   Reply With Quote
Old 01-15-2018, 10:46 AM   #10
Irace86.2.0
I haven’t been able to lock down a pattern. It seems to be random.
Old 01-16-2018, 02:00 PM   #11
Brz_racer
Drives: Subaru BRZ
Check the connection to the bulb itself, moisture may have got on the connection, I would disconnect the plug to the bulb and clean it with contact cleaner and see if that helps. Also make sure the connection at the bulb isn't loose at all.
interior dome light danielremjativa Cosmetic Modification (Interior/Exterior/Lighting) 15 07-21-2016 12:52 PM
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 09:39 PM
Interior Dome Light Issues Mongo Issues | Warranty | Recalls / TSB 3 03-19-2014 04:52 PM
Dome light not turning on Vincenttam Scion FR-S / Toyota 86 GT86 General Forum 2 01-12-2014 02:51 AM
