Old 12-21-2017, 11:27 AM   #1
f3nix.02@gmail.com
f3nix.02@gmail.com's Avatar
Drives: 2013 FR-S, 2002 WS6 Trans Am
Issues after transmission replacement
Hello everyone, this is my first post on here and I hope I can get some insight on my issues. I have a boosted 2013 FR-S that is currently tuned with ECUTEK. My transmission started to go out and since I'm still under warranty the dealer replaced it for me. After the replacement they called me because the car was in safe mode and did not rev up according to them. At first they thought somehow my tune had something to do with it so I went there and reloaded it. Everything loaded fine but I instantly tripped 6 codes: P0333, P0328, P0123, P0223, P0198 and P0193. When I try to clear them they come back on. It didn't have any CELs before going in, has anyone had this issue before?
f3nix.02@gmail.com is offline   Reply With Quote
Old 12-21-2017, 11:45 AM   #2
ermax
ermax's Avatar
Man they can always fine something to blame bad work on. My guess is the the harness interconnects on the back of the engine aren’t secure. When dropping the tranny you unplug all the harnesses. You would think they could troubleshoot this on their own though.
Old 12-21-2017, 11:58 AM   #3
davidsn_670
Drives: 2015 Scion FRS
With codes immediately coming back for sensors, sound likes they left some wires disconnected or pinched/broke the wires during removal/install. Usually "circuit high" indicates an short to power, or open in the ground circuit. They could look at those sensors data and see if they are responding at all and go from there. If all else fails, you could do a "cap" discharge. You just disconnect both battery terminals and put a jumper wire across them causing hard reset on modules. Hope this helps at all!
davidsn_670 is offline   Reply With Quote
Old 12-21-2017, 03:47 PM   #4
f3nix.02@gmail.com
Apparently there was a pin that was bent and they fixed it on one of the Harnesses. Now there's only one code (P1235) but it runs really rough and cannot go into higher RPMs.
Old 12-24-2017, 07:50 PM   #5
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
Did you ever get this fixed? What was it? I'm about to get my trans replaced too under warranty for bad synchros...but I'm naturally aspirated.
chazmuska is offline   Reply With Quote
Old 12-28-2017, 07:54 PM   #6
Decep
Drives: 2013 FR-S Series 10
honestly amazed OP got the dealer to replace the transmission under warranty on a boosted twin.
Old 12-29-2017, 05:54 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Yeah they get the 2017 award for best dealership in the world.
Old 12-29-2017, 09:53 AM   #8
bababooey
Drives: BRZ SWP Limited -6MT
testimonies like these is what gets people in a tizzie with stonewall's that dont wanna play ball
Transmission Issues (AT) RichardJ Engine, Exhaust, Transmission 1 03-24-2017 08:47 AM
6MT Transmission Grind -> Warranty Replacement (Subaru) Fred E NY / NJ / CT / PA 7 11-06-2015 11:18 PM
Transmission issues SrgtSnuggles Engine, Exhaust, Transmission 7 09-18-2015 11:40 PM
Transmission replacement Ludacrits Issues | Warranty | Recalls / TSB 1 04-30-2014 07:02 PM
Transmission issues... Rob_g Issues | Warranty | Recalls / TSB 13 09-23-2012 07:40 PM
