Old 03-24-2017, 12:34 AM   #1
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Unhappy Transmission Issues (AT)
Hey guys, I'm an owner of a '15 FRS. I'm experiencing a problem and I would appreciate some help.
Premise:
I recently installed Weir's 4.88 FD and I've been enjoying it for over a month.
Work has been done by a reputable local shop where the owner's frs (MT) has the same mod. I was assured the install went flawlessly as he has lots of experience with this. The car has not been re-tuned after the install.
The issue:
While the car is fine most of the time. But after switching back and forth from sport to manual mode during moderately long drives, the transmission has been acting oddly. The RPM suddenly drops to exactly 1k rpm and when I gas it, the engine revs as if it's in neutral gear. This happens on all modes (normal/sport/manual).
Sometimes it fixes itself after few minutes. Turning the car off and restarting it seems to fix this issue.
It's confirmed that not putting in sport/manual mode from the get go never reproduces the issue.
Did some research and it seems AT BMW's with manual mode has this issue as well. They enter a "failsafe mode" activated because of a change in shifting patterns not recognized by the TCU or due to extreme wear on the transmission and gear slippage.
Any suggestions will be greatly appreciated.
RichardJ is offline   Reply With Quote
Old 03-24-2017, 08:47 AM   #2
projectXTR
Drives: Sterling Silver BRZ
Have you disconnected the battery to reset the ecu?
projectXTR is offline   Reply With Quote
Transmission issues SrgtSnuggles Engine, Exhaust, Transmission 7 09-18-2015 11:40 PM
Transmission issues (or me being too anal) Pkush Issues | Warranty | Recalls / TSB 18 12-06-2014 10:43 PM
manual transmission issues. DriftEightSix Engine, Exhaust, Transmission 24 06-10-2013 08:25 AM
manual transmission issues XtremeMaC Engine, Exhaust, Transmission 4 10-10-2012 06:40 PM
Transmission issues... Rob_g Issues | Warranty | Recalls / TSB 13 09-23-2012 07:40 PM
