Old 12-16-2017, 12:11 AM   #1
eddwvrd
Drives: Frs
Frs coolant
So last week I checked my coolant and it was full but yesterday i went to clean the engine and I noticed that my coolant was halfway. Is that normal? Also in my area right now is cold. I dont know where is the a/c compressor located and i saw underneath the engine (driver side) a small amount of droplets loll im thinking its water? but i didnt turn on my a/c only the heater.
eddwvrd is offline   Reply With Quote
Old 12-16-2017, 12:17 AM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
By half full; do you mean the radiator or overflow?
Cause: Overflow at half is normal. Radiator half full is not normal.
I LIKE TIRES!
Old 12-16-2017, 12:29 AM   #3
eddwvrd
Drives: Frs
Overflow is the coolant resorvoir right? Yeah its half.
Old 12-16-2017, 12:35 AM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes. If you take the cap off the radiator, I bet it's full. The system has the overflow/reservoir because the level fluctuates with use.
I LIKE TIRES!
Old 12-16-2017, 12:41 AM   #5
humfrz
Hello eddwvrd,
I suggest you check your car's drivers manual for some more information.
On my 2013 FR-S, I like to see the level of coolant in the overflow tank about half way between the full and low lines, when the car is cold.
If the level falls below that you may either add the recommended "blue" stuff or if it just needs a little, some distilled or de-mineralized water will be OK.
The drops of liquid on the floor under your may be ice from the A/C condenser melting off. Even though you don't have your A/C "turned on" it will still run if the defrosters are being used.
To find out taste it ...... if it tastes like oil ..... it's oil; if it tastes like water .... it's water ...... if it tastes like the blue stuff in the coolant tank ..... it's coolant (don't drink it! .......).
Any other questions .......
humfrz
Leonardo (12-16-2017)
Old 12-16-2017, 12:43 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
How have you managed to survive this long?
Leonardo (12-16-2017), Teseo (12-16-2017)
Old 12-16-2017, 12:48 AM   #7
humfrz
Just lucky that no jealous husbands have caught up with me ....... yet ......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
finch1750 (12-19-2017), Leonardo (12-16-2017), Teseo (12-16-2017)
Old 12-16-2017, 01:29 AM   #8
eddwvrd
Drives: Frs
What coolant should i use? Does toyota and subaru have the same coolant for the 2013 frs? Can i buy it at walmart or other auto shops? Sorry for a lot of questions i forgot to bring my drivers manual when i went to a different state.
The Following User Says Thank You to eddwvrd For This Useful Post:
Old 12-16-2017, 01:37 AM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Pretty sure you can download on here. http://www.ft86club.com/forums/showthread.php?t=8374
Better link.
I LIKE TIRES!
Old 12-16-2017, 02:20 AM   #10
humfrz
The manual will specify "Toyota Genuine 50/50 Pre-mixed Super Long Life Coolant BLUE".
Yes it's pricy but this is NOT the place to skimp, unless you have a PhD in chemistry and you know the proprietary ingredient that isn't specified on the MSDS.
Now, that stuff is 50% special coolant and 50% deionized water (that mixture will protect the cooling system down to -31 degree F).
So, since you are in Virginia, it would be just fine to top the coolant level with either deionized or distilled water (found at any grocery store).
So, just get yourself a jug of distilled water and pour a cup or two in when the level gets low and don't worry about it.
Back-in-the-day, before permanent anti-freeze was invented, we would just use a 50/50 water alcohol mix. Life was simpler ....... and when you would get pulled over, and had been drinking, you could just tell the LEO that the smell of alcohol was your radiator boiling over.
humfrz
Old 12-16-2017, 02:44 AM   #11
eddwvrd
Drives: Frs
Right now im in Tennessee and probably going to stay here for 6months loll. Thanks for the info. I dont wanna ask these kinds of questions on other groups cos most of them trolls and i wont get the answers that i needed haha
Old 12-16-2017, 02:49 AM   #12
Ultramaroon
not playing cards
Is Google illegal in Tennessee?
Old 12-16-2017, 02:59 AM   #13
Ultramaroon
not playing cards
Here
https://www.toyota.com/owners/resour...uals/fr-s/2013
Literally fifteen seconds
Old 12-16-2017, 03:30 AM   #14
humfrz
Oh, now, grumpy, please understand that communications just move slower in Tennessee .......
humfrz
Ultramaroon (12-16-2017)
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 01:09 AM
Coolant low RedNWhite Scion FR-S / Toyota 86 GT86 General Forum 13 05-24-2016 12:17 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
is my coolant low? chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-19-2013 11:43 PM
